What PSI is a 1996 Saab Turbo Gated at stock
I picked up a little t3 from a wrecked 96/97 2.0 Saab 900 Turbo yesterday, and I was wondering what the wastegate actuator is set at from the factory, so I could decide if I wanted to keep it on there or go external. TIA!
Re: What PSI is a 1996 Saab Turbo Gated at stock (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">it's usually between 12-14 psi...on volvo or saab T3
stan</TD></TR></TABLE>
****, I was hoping a little less, do you think this would do ok on a stock bottom end Z6
Re: What PSI is a 1996 Saab Turbo Gated at stock (saywhat)
There are way's to modify internal waste gate's to lower the boost. You can tweek the postion of the actuator, or cut/thread/coupler the WG rod to adjust the pressure, or use a spring.
Re: What PSI is a 1996 Saab Turbo Gated at stock (Jeffescortlx)
hmm.. it has a threaded rod on it right now, I imagine the longer the rod the less pressure to open the flapper thus fewer pounds
89civic1.8T
05-18-2002 11:23 PM
