what are people doing to dipsticks on moroso oil pans?
are you welding more to the dipstick?
Re: what are people doing to dipsticks on moroso oil pans? (Del Sol on Steroids)
no reason to. the oil level when full will be at the same point
Re: what are people doing to dipsticks on moroso oil pans? (BadWay)
exactly. the point of the oil pan being deeper is so that you can hold a higher oil capacity, not because it looks cool.
Re: what are people doing to dipsticks on moroso oil pans? (CoreyR)
OEM Dipstick with mine, 5 quarts puts it a hair above the full mark
Re: what are people doing to dipsticks on moroso oil pans? (96 GSR-T)
i put in 6 qt. and it doesn't even reach, when cold that is.
Re: what are people doing to dipsticks on moroso oil pans? (rota92)
5.5 is the capacity
I use a golden eagle dipstick with mine. Works fine and has a metal top that won't melt from my ramhorn manifold.
Re: what are people doing to dipsticks on moroso oil pans? (sp00led)
I put 5 quarts in my moroso and its on the money. Are you using your stock dip stick on your set up?
Re: what are people doing to dipsticks on moroso oil pans? (Redwidow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow »</TD></TR><TR><TD CLASS="quote">I put 5 quarts in my moroso and its on the money. Are you using your stock dip stick on your set up?</TD></TR></TABLE>
Same with me until I added an oil cooler. |
stock dipstick
i'm gonna try that golden eagle one.
just wanted to know when i boost, if i'm burning any oil. don't want it to seize. also is 70-90 oil psi normal in cold weather |
70-90 is what I get.
