What parts do I need to install my turbo ???
Ok I got a turbonetics t04e turbo which I am putting in my crx. I need to know what else will be needed before I get it installed. I only want to know exact items to get it installed and running, for instance I am not going to put on an intercooler yet because I don't have the money to buy one. I just want to know what is absolutely necesarry for the install. All parts that can be bought and installed later will have to wait for now because of a limited budget. Please let me know what I will need, Thanks guys.
New User
Re: What parts do I need to install my turbo ??? (Krow)
what i can think of off the top of my head is fuel pump,fuel pressure regulator,flange for the turbo,downpipe,header,gaskets,wastegate,turbo piping, and map bypass valves. u can see a list at importparts.com under drag parts....
What is this crap?
well, the bad news is that the best advice you are gonna get here is that you have to do some research and figure out what you need. only you can determine what you can afford and what you need. good luck.
and tell us a little about that badass motor you have to use with that turbo.
Joe
Joe
Texas B*tch!
Re: What parts do I need to install my turbo ??? (falconGSR)
Agreed w/ Falcon, do your own research by looking at some previous posts. And it's an exhaust manifold that you're looking for, close to a header, but you can't attatch a turbine to one.
Re: What parts do I need to install my turbo ??? (ForcedAccord)
Thanks guys, I have been doing searches trying to find out as much as I can about how to setup my turbo. It will be going on either a zc, or a b18a I still have not decided on witch swap to get, I will choose by the end of the month and probably get it all done over the winter. If I get the b18a it will blow most of my funds, and if I go zc it will not be as powerful but it will give me another $1k dollar to spend on the turbo setup. Thanks for all the help guys.
The motor will make quite a bit of difference. You would probably want a different turbo for this motor or that ... for instance I have a D16 and I'm not going to run a turbo that will make lots of power over 8000 RPMs, like you would want on a B18C.
GroundZer0 336
07-30-2003 10:49 PM
