What other injector clips are the same as 94-95 GSR clips?
Ok,
Just solved one of my problems below, by buying some used 310 injectors off pornstaR's GSR kit, only thing is he said that I would need some injector clips off a 94-95 GSR, he said that they are not RC injectors but they are Greddy Injectors
What other vehicles have injector clips that are compatible with them?
What other types of Honda's? or any other makes?
[Modified by xdsmguy, 4:36 AM 9/6/2002]
Re: What other injector clips are the same as 94-95 GSR clips? (xdsmguy)
You can use the fuel injector clips off of any Honda/Acura from 84 to 95 as long as they came from a fuel injected car. The old stuff (91 and earlier) is the same pattern, but uses a different retainer. It will still work.
Sonny
Sonny
Re: What other injector clips are the same as 94-95 GSR clips? (Sonny)
Ok
I think I found some old injector clips from an OBD1 car, however there aren't any wires coming from the clips, Do i just solder some in?
Also, for a last resort, somebody said that I could just "make" my current clips fit, true or not?
Panoply
07-18-2005 09:36 AM
