what oil system is needed for 500+ hp?
are there any mods needed to perform on the oil system running these numbers? the only thing i could really think of is replacing the oil pan....but what else? all comments and help is appreciated!
thanks in advance
thanks in advance
Re: what oil system is needed for 500+ hp? (Dublocivic)
but i have seen people that change to a diff oil pan and run a slump on drag cars. so i had the sam question as bubba55 if stock oil components are okay thanks
Re: what oil system is needed for 500+ hp? (jkjb16a)
If your just trying to spend some money you could install an oil cooler, which would obviously be beneficial. Wether or not it would be necessary for your setup, I have no idea... Good Luck!
Re: what oil system is needed for 500+ hp? (Bubba55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bubba55 »</TD></TR><TR><TD CLASS="quote">are there any mods needed to perform on the oil system running these numbers? the only thing i could really think of is replacing the oil pan....but what else? all comments and help is appreciated!
thanks in advance</TD></TR></TABLE>
you will be fine if your oil pump is old then i would replace it if not you are good to go.
The only addition to my oil system I am doing is replacing my stock oil pump gear with a Prodrive gear.
Re: what oil system is needed for 500+ hp? (TurboR1391)
When people say their oil pumps took a ****, is it the actual pump, or is it just the gear that cracks? So just a prodrive gear is good enough for an oil pump woth 70k miles?
No Sales Forums
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboR1391 »</TD></TR><TR><TD CLASS="quote">The only addition to my oil system I am doing is replacing my stock oil pump gear with a Prodrive gear. </TD></TR></TABLE>
that is good insurance. at least its one thing you dont have to worry about
Re: what oil system is needed for 500+ hp? (m R g S r)
It is the gear that shatters as opposed to the housing.
If you rebuild with a new OEM oil pump+gear you'll be all set. If you don't use a harmonic balancer (like using a solid crank pulley) you are asking for trouble.
Ben
Ben
