what msd distributer cap for honda distributer part #TD-68U 4723?
I have a turbo ls vtec and i have been having a hard time looking for the correct MSD distributer cap. i dont know what motor the distributer came off of. The Markings on the distributer say TD-68U 4723. Ive tried a msd distributer cap that is for a GSR but it didnt fit. Can anyone tell me what part number cap i should use and what motor my distributer is off of?
thanks
mike
The correct cap for a TD68U distributer is MSD part# 82933
Modified by 92redhatch at 9:24 AM 9/7/2007
thanks
mike
Re: what msd distributer cap for honda distributer part #TD-68U 4723? (92redhatch)
I had the same problem couldnt find one. So i just used the cap i had and only put 2 bolts in it car runs fine
i was under the impression that the td-44u and td-68u were interchangeable and would work on any obd1 b16 or gsr. since you've tried the gsr maybe look into a b16 cap.
edit: i just referenced part# from an obd1 b16 and obd1 gsr and the cap doesnt match so maybe thats why you had problems with the gsr cap.
are you using an msd cap on an oem dizzy? if so why not just use an oem cap.
im using an external coil thats why i need the msd distributer cap. the gsr cap was almost the same as the sohc civic cap and it was exactly the same as the integra ls cap.
im using a factory distributer.
anyone else know what the part number i need is? and from what car?
the gsr one is to small. ya im sure i can get 2 bolts to fit but i need the right one. this is going to be on a car thats going to make over 500whp. i dont want to ghetto rig it.
