What manifold is your choice on a turbo set up
I have a stock type r manifold with the runners ported and gasket matched the throttle body opening is opened to match up with my 68mm throttle body.
im planning to make close to 600 hp on a 2.0 with r cams do you think this intake manifold will be adequate or what manifold would you guys run and how much more hp should i expect if i step it up to a real intake mani
Re: (ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 »</TD></TR><TR><TD CLASS="quote">The victor x is only useful for the 7k-10k powerband, so when you shift if you land in that range then use it, otherwise go with the performer x</TD></TR></TABLE>
you think the plenum is big enough on the performer X to support 600whp?
poison
10-25-2003 07:49 AM
