what kinds power do u guys estimate???
I have a jdm b20 BONE STOCK with a sc34 log mani, 580 cc, 255 walbro...if I have a real good tune how much power do u think I COULD see??
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">325</TD></TR></TABLE>
This. I can see your 580s being pretty much used up by then.
Man U FTW
The rule for injectors is 6cc per whp. If you use that method, the 580s are as follows:
580cc x 4inj = 2320cc (total)
2320 / 6cc per whp = 386.667whp at a 75-85% duty cycle
You can safely make up to 387whp on those injectors at stock fuel pressure. They technically CAN make more, but i wouldn't expect a lot more out of them.
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">The rule for injectors is 6cc per whp. If you use that method, the 580s are as follows:
You can safely make up to 387whp on those injectors at stock fuel pressure. They technically CAN make more, but i wouldn't expect a lot more out of them. </TD></TR></TABLE>
Yeah, I figured I undershot it a little bit but it's better to do that with an injector than overshoot.
Curious though, how are you getting 75-85% duty cycle out of that? Is the 6cc/whp coming to that conclusion?
Man U FTW
Its just a general rule based on what i've seen around. People used to base injector sizing on 5cc per bhp, but that's not a great measurement since you have to then guess at what whp you'll make. The 6cc per whp is not meant to be deadly accurate, but rather, give you a good idea where you should be about. If you're looking to size injectors and you hit your power goals within a little bit of the 6cc per whp range, its fine.
Basically its just an easy way to get in the ballpark..
Re: (Schister66)
Gotcha. Yeah, I've got my Maximum Boost book sitting here in my schoolbag with all of the calculations highlighted and tabbed.
Wasn't about to break it out just for this though. 6cc/whp is the first I've heard of it, good ****.
Man U FTW
Re: (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">Gotcha. Yeah, I've got my Maximum Boost book sitting here in my schoolbag with all of the calculations highlighted and tabbed. </TD></TR></TABLE>
That's a good read...i still have yet to go through most of it, but i have a .pdf copy on my laptop. If i find some time, i'm going to incorporate it into a nice little write-up for the FI Forum (it'll be better than the G2IC Boost FAQ)
Re: (Schister66)
That's a good read...i still have yet to go through most of it, but i have a .pdf copy on my laptop. If i find some time, i'm going to incorporate it into a nice little write-up for the FI Forum (it'll be better than the G2IC Boost FAQ) </TD></TR></TABLE>
If you want help let me know. I read the book between classes in school a lot. The only problem I have is that the author focuses too much on psi being the hindering aspect of turbocharging an engine and not torque made or better yet a combination of both with turbo/intercooler efficiencies and all that stuff.
Otherwise, great book indeed.
Re: (Schister66)
well I have a 2.5 inch dp into 2.5 inch piping to a virbrant muffler...dont think I could make 300 (which is what I am shooting for) with that or should u run open dp??
Re: (T9U4ReBgO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO »</TD></TR><TR><TD CLASS="quote">well I have a 2.5 inch dp into 2.5 inch piping to a virbrant muffler...dont think I could make 300 (which is what I am shooting for) with that or should u run open dp??</TD></TR></TABLE>
Full 2.5" is fine. Seriously, a simple clean setup with what you have will do 300 no problem and be perfectly safe with a good tune.
Man U FTW
Re: (SovXietday)
Full 2.5" is fine. Seriously, a simple clean setup with what you have will do 300 no problem and be perfectly safe with a good tune.</TD></TR></TABLE>
x2...you'll be fine with a 2.5". You'd be better with a 3", but that's "ideal"
06-12-2009 06:49 PM
