What kind of TURBO would you put in if you had a 1991 CR-X SI?
Someone said that a 14B was a good one.
Re: What kind of TURBO would you put in if you had a 1991 CR-X SI? (IS300ruler)
If you are using the Stock D16a6 that comes in that car i would do a 16g or 18g....... 14b are good, my friend has one on his junkyard turbo kit on his d16a6 but it has no top end power at all...... FOr example....... It gets full 9psi by like 3000Rpm and decreases in boost to about 6.5 - 7psi on the top end..... 16g and or 18g would yeild alittle lag down low but give you some aggressive top end https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: What kind of TURBO would you put in if you had a 1991 CR-X SI? (Outkast)
The cheapest would be one of the volvo or saab T3s. A 14b or t25 will have nice midrange power but will fall off up top. I have had a t25 and now a .63 & .48 a/r T3 made from saab and volvo parts. The T3 spools up about 300 rpm later (6psi at 3000rpm) than the T25 but the T3 pulls hard to 7500 not like the T25s 5500 ceiling. The T3 a 5psi makes me happier than the T25 at 9psi https://honda-tech.com/forums/images...es/emsmile.gif
