What injectors you guys think i should run?
Im looking to run around 16psi and i do have the b&m regulator and gauge.
Setup:
b18c1
greddy 18g 2.5 downpipe
str blockgaurd
eagle rods
JE 9.8:1 pistons
crower stage 2 cams
crower springs and retianers
stock valves
full msd ignition
Vafc fuel
Avcr boost
Clutchmasters flywheel and clutch
I have RC 310cc now and im sure these are not enough.
I have an integra im partingout with seats dash and some other parts Im willing to trade for another set.
Setup:
b18c1
str blockgaurd
eagle rods
JE 9.8:1 pistons
crower stage 2 cams
stock valves
full msd ignition
Vafc fuel
Avcr boost
Re: What injectors you guys think i should run? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">i would run precision 780 or 880cc injectors</TD></TR></TABLE>
Don't some fuel rails have to be modified to work with the precision injectors?
I like the RC 750's.
Re: What injectors you guys think i should run? (TurboChrgd_Civic)
the precision injectors are direct fit to any rail they are machined and ready to go and cant beat there price at aroudn 70 an injectors
Re: What injectors you guys think i should run? (GForceInteg)
Again if anyone has any they might want to trade for some other parts. I have a 98 integra gsr im parting out.
Re: (DaX)
Ok now does anyone out there have some injectors wanting to trade for some parts I blew my load on the engine parts as i went and forgot the rc's i got with my breddy kit would probably not keep up
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">I would go 780cc just so you have room for expanding. It never hurts to have your injectors on a low duty cycle! Just don't go over 880cc or you may have idle problems.</TD></TR></TABLE>So you're saying that you can use the vafc with the 780cc injectors and still idle? I'm curious cause I'm in a similar situation with my setup.
* B A N N E D *
Re: (1bad-eg)
man 700cc and + is over kill!!!!!!!!!...
you gotta kno your HP goal.. but since i think you want it streetable with out getting a chip or hondata...i say 440cc...plenty for 300+hp..
Re: (ShowTymers619)
Let me put it this way. I expect to be pushing anywhere from 15-20 psi with my setup. t3/t4 turbo, .70 on the cold side .63 on the hot side. I have a chipped ecu right now, eventually upgrade to hondata s200. Gforceinteg has a very similar setup to mine. I just wanted to know if the chipped ecu with a vafc hack idle with big *** injectors.
Mike95lude
12-21-2007 10:13 AM
redline201
07-12-2003 11:35 AM
KStuned
01-03-2003 04:23 AM
