this is what i have for turbo kit what else do i need.....
I am turboing my h22a4 in my 95 eg
so far i have garrett t3/04e 57trim
lovefab shorty
inline pro mandrel bent piping
greddy type s bov
boost, a/f, oil pres gauges
dsm 450cc's
pickn up vafc controler this weeknd (gonna run afc hack)
tyrus 6" fmic
ordering tial 38mm wastegate with like a 5.5 or 6psi spring....
what else do i need like for afc hack..other then dsm injectors and vafc controler....waht do i need to do about the map sensor i was gonna get the blue thing or whatever is that all i need? what do i do about my ecu its usdm 97 or 98 motor and ecu.....
lovefab shorty
greddy type s bov
dsm 450cc's
tyrus 6" fmic
Re: this is what i have for turbo kit what else do i need..... (gdrum)
You will need silicone couplers for you IC piping, hose clamps, T fittings for vaccum hoses, vaccum hoses, flange for type S to be welded onto piping, resistors for the injectors or a resistor box, fuel pump, a downpipe, and some sort of filter for your turbo. Oh, and nuts, bolts washers, lock washers to keep things tight.
Re: (siffredi)
yeah i was gonna wire resistors into injectors...........can i use hose clamps and couplers form like hardware store? flange is already welded on the dp....i was gonna order oil line kit from homemadeturbo.....downpipe not sure how imma get that made....i just dont understand and hope i have everything for fuel mangemaent other then that.......spark plugs thinkn 2 stages coldre? Not sure about retarding or advancing timing....was gonna run mobil 1 15w50 in it..
Re: (gdrum)
and for fuel pump.....i bought car with h22 in it...guy did the swap but i read u have to put a walbro or something like that in there...because the stock hatch pump wont push it.....so i assume mine has high flow pump but i am totally not sure.......dont know how to tel....was gonna try it see if it worked
also for my lovefab t3 manifold and my t3/04e is ther ea plate i have to buy to bolt the turbo to the manifold...or itj ust bolts up do i need a gasket or what....
Re: this is what i have for turbo kit what else do i need..... (rocket256)
Yeah your going to need a walboro 255 and a 12:1 fmu. You need a good clutch to put that power to the ground.
Re: (gdrum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum »</TD></TR><TR><TD CLASS="quote">can i use hose clamps and couplers form like hardware store?</TD></TR></TABLE>
u can but they will probably blow off, go to like napa or advance etc. and get some big truck (heavy duty) coolant hose, thats what i did, works like a charm
and also, make sure you get the good airplane hose clamps, not the cheap ones from the hardware store
Re: (civicb18)
yeah i have tokico blues right now, eibach sportlines........prob gonna switch to eibach pros eventually.........i think i have a walbro 255lph not sure thoe, how would i find out......runnin afc hack....i have act stage 2 clutch with fydanza flywheel...so those areas are cover........but thanks for what to use for the hose and the clamps..thatll make things easier.....and when i put the t3/04e on the lovefab shorty.....i know i need a gasket...do i need like a flange or adpater or anything or does it just bolt up....and gasket it between...
OG SHG_EM1
03-28-2004 09:10 PM
