what the hell is turbo lag?
does it only occur in 1st gear or does it occur between every shift while in boost?
explain please. |
Re: what the hell is turbo lag? (biada1)
pretty sure turbo lag is the time it takes for your turbo to spool back up between shifts
larger turbo = more power but more lag smaller turbo = not as much power but less lag hope that helps and if im compleatly wrong.. sorry.. |
turbo lag normally occurs on small engines with large turbos. turbo lag is when an engine does not produce enough exhaust flow to spool up a turbo until higher rpms. since the large turbo does not spool quickly it does not give you power down low in the rpm range and this is known as turbo lag.
Re: what the hell is turbo lag? (petty$rep)
It's the "wait for it, wait for it .... AAHHHHH" feeling in a turbo car.
Kind of like when yo_ eh... that's not really appropriate. |
Re: what the hell is turbo lag? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">It's the "wait for it, wait for it .... AAHHHHH" feeling in a turbo car.
Kind of like when yo_ eh... that's not really appropriate.</TD></TR></TABLE>lol's perfect explanation https://honda-tech.com/forums/images/smilies/emthup.gif |
Drive an SS/WS6/Mustang V8, keep it in 3rd gear on the freeway, then punch it. Immediately pushed into your seat.
Take a heavy, stock GSR, and [from a stop] drive up to 65mph in 2nd gear. Note 'vtec' warping you to light speed near the end ( https://honda-tech.com/forums/images...s/emsmilep.gif ) The latter is most like turbo lag. On a Honda, the turbo's shaft spins around 100,000-150,000 rpm's in boost, yet just a few thousand while cruising. Some are too big on hondas to spin at idle. Blink your eye once, and a spooled turbo has spun 500 times around https://honda-tech.com/forums/images...s/emsmileo.gif That should give you an idea what causes turbo lag. <U>Engine load determines energy put into the turbine, and shifting/cruising/idling are all low-load conditions, WOT is high-load</U>, as is taller gearing to an extent. |
Re: what the hell is turbo lag? (HiProfile)
The time it takes for the turbo spool. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: what the hell is turbo lag? (RevTek 6)
Turbo lag is when you go cheap and don't get a ball bearing turbo https://honda-tech.com/forums/images...s/emsmilep.gif
Re: what the hell is turbo lag? (rota92)
Turbo lag was developed on Hondas to let the supercharged v8s get a head start during a race to make it more even.
Re: what the hell is turbo lag? (aaronISthrowed)
turbo lag = traction
Turbo lag is the time it take from you hitting the throttle, to the combustion of the engine makes the turbo blow in fresh charge air https://honda-tech.com/forums/images/smilies/emwink.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed »</TD></TR><TR><TD CLASS="quote">Turbo lag was developed on Hondas to let the supercharged v8s get a head start during a race to make it more even.</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif signature material right there |
100,000-150,000? Lol
You mean 50,000-70,000? |
Re: what the hell is turbo lag? (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec »</TD></TR><TR><TD CLASS="quote">Turbo lag is the time it take from you hitting the throttle, to the combustion of the engine makes the turbo blow in fresh charge air https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE>
This is the only correct reply here. Everyone else is talking about spool rpm as if it were turbo lag. If you're too low in the rpm band, it doesn't matter how much gas you give it, it won't spool up. If you're past the minimum spool rpm after a shift, there is still a delay between hitting the gas and the turbo doing its job. That delay, and only that delay, is turbo lag. Google search Notice how none of those definitions mention getting it up to an rpm where you can spool up the turbo. |
Re: what the hell is turbo lag? (slogins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slogins »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif signature material right there</TD></TR></TABLE> haha thanks. |
| All times are GMT -8. The time now is 05:31 AM. |
