What is a good reading on the widebande at high rpm/
I'm doing some tuning on my car I think it's a lill lean on top end I'm geting 13 14's some 12's. At idle a lill rish I know it's not bad to run a lill rish. What kind's of reading's are you guys geting? Might have to turn the boost down
Re: What is a good reading on the widebande at high rpm/ (fast[R])
I would suggest an A/F ratio of between 12.0 - 12.7 for turbo'd Integra's with a good intercooler and efficient turbine. This is considered by most tuners to be a safe area (dependent upon each specific car). Make sure you listen for knock and it is advisable to get a J&S Safegaurd to be on the safe side.
What psi are you running?
New User
11.5-12.5 is generally considered to be the "SAFE" zone on a stock high compression engine.
Re: What is a good reading on the widebande at high rpm/ (dbman96)
Sory I left something out my comp. is now 9;1 je pistons don't know if it will change enithing.
PGT Driver
04-24-2004 10:51 AM
