What is a good a/f ratio for turbo sohc?
set up
-sohc d15b7,y7 head
-cr 10.1:1
-7psi non-intercooled
-fmu
-255 fuel pump
My a/f ratio is in the 14's at all rpm. I have detonation at full boost. I know i need a intercooler, but do I need a lower fuel ratio to get cure the detonation?
Modified by civic dx at 1:46 AM 8/24/2003
-sohc d15b7,y7 head
-cr 10.1:1
-fmu
-255 fuel pump
Re: What is a good a/f ratio for turbo sohc? (civic dx)
14.x:1 is WAY lean...
12.8:1 is about as lean as you want to run any turbocharged street car...and the closer to 12:1 you get, the safer it is...generally speaking, of course every car responds differently.
What size injectors are you running? And what fuel pressure @ 7psi of boost?
Re: What is a good a/f ratio for turbo sohc? (NaperNeonRT)
i am running my stock 230cc injectors. do i need bigger injectors of a bigger fmu disk?
Re: What is a good a/f ratio for turbo sohc? (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c »</TD></TR><TR><TD CLASS="quote">12.5 under boost is pretty good.</TD></TR></TABLE>
Exactly what I tuned my hondata at.
GOLDBERG
04-13-2003 05:16 PM
