What gasket set to use for .25mm over??
Im just finishing up my first build here. it has .25mm over standard size (81.25) pistons and i was wondering what gasket set i should be using? the block is a ls block with a vtec head. i was told by my friend i can just use a stock size 81mm gasket set? do they make a gasket set .25 over? sorry if this might be a dumb question but this is the only thing thats stopping me from finishing this build. thanks in advance.
the stock gasket will definately be fine.
Re: What gasket set to use for .25mm over?? (bnut510)
"they" dont make one that i'm aware of but "someone" can bore the gasket. i would just use the 81. thats what im doin on my 81.5.
Re: What gasket set to use for .25mm over?? (agrn93ls)
ok thanks... will be ordering today
oem will be fine. you can even use it for an 81.5 setup, ive done it no problems
