What do you guys think of these gauges?
SPA dual digital gauges
Here is a groupbuy page on them
http://www.groupbuycenter.com/buy.aspx?id=9159
They seem pretty net given that you can have 6 measurements in only 3 gauges.
Are digital gauges more accurate then analog, since there is no mechanical movement?
1 Post
Re: What do you guys think of these gauges? (Pat)
they look nice..ive heard people running them with a trigger so that they use also as a turbo timmer....the car turns off after the oil cools down to a certain temp.
But IMO id rather have a needle to tell me where im at.......Im more visual and having a needle in a guage, can give me a better idea on how hot the oil is or where i am on boost.
Re: What do you guys think of these gauges? (Cramerox)
Digital gauges are nearly impossible to read i think. It's so much easier to see an analog readout. For instance: Your running dead nuts 9 psi and its solid....all of a sudden you hit a little boost creep then the digital guage reads 20 psi, where on a normal guage you might be able to catch it.
I dunno if im really feeling them. I would prefer your "average" guage before those. Something about the digital layout doesn't interest me as much.
They are OK I guess.
Re: What do you guys think of these gauges? (boostedsol)
most racecar teams mount there guages so that all the needles point up when normal... that way its a whole hell of alot easier to tell if somethings off, just look for the needle thats not pointing up.
Is it just me, or does the Boost/EGT gauge in the lower left corner read 45.7 lbs of boost, and 139.9 Degress Celcius for the EGT?
What the hell kind of a car give THOSE readings?
Re: What do you guys think of these gauges? (johnisenglish)
those gauges probably do got a lot more function than most of the other gauges out there but form is important to me too... honestly, those gauges look like ***... try and find some nicer looking ones that also work well...
Re: What do you guys think of these gauges? (GZERO)
yeah, but why if is measured in some other measure
Re: What do you guys think of these gauges? (T3T495GSR)
being digital, they can switch between different metric and imperial measurement.
I'm looking to get a fuel/oil pressure and water/oil temp combo. For boost and egt, I'm looking to get this:
Digital gauges look pretty sweet, not too sure on how accurate they are though. In terms of taking a quick glance while driving, the digital gauge might take longer to focus on than a conventional gauge. It's a conversation piece, not bad looking but depending on price, not a necessity. To each his own
thumper64
03-10-2010 09:35 AM
1DayIllBFast
05-09-2009 11:25 PM
