You guys wanna help me design my exhaust?
Old 05-18-2016, 09:41 PM
Dur Da Dur
hondur's Avatar
Default You guys wanna help me design my exhaust?
As of now, my D16Z6 is N.A., I've got a generic ebay header on it. But, I've got a TD04HL13G that i'm going to put on it sooner or later.
I was going to use the exhaust from my parts car, but that thing is a piece of crap. It's got a couple pipe sections welded in, no cat, and all the gaskets were replaced with welds. So this parts car exhaust isn't gonna work for me.
I'm trying to keep costs low, so I'm thinking that i'm gonna use the main catalytic converter off my V6 accord. That car had 244 BHP, and my civic is going to be around that number. Do you figure that the V6's cat will work well on the turbo civic?
Old 05-18-2016, 09:51 PM
-Intl Steve Krew
Caoboy's Avatar
Downpipe straight out the side of the bumper. See how easy that was?
Old 05-18-2016, 09:56 PM
Dur Da Dur
hondur's Avatar
Default Re: You guys wanna help me design my exhaust?
nah man, I want my emissions to be clean. This is going to be my D.D.
Old 05-18-2016, 10:11 PM
Dur Da Dur
hondur's Avatar
This is my turbo's flange, the one that bolts to the downpipe.
I can't seem to find any downpipes that will work with this. I'm searching on google shopping, ebay, all the cheap stuff. Everything I find is 5 bolts, not three.
I figure i'm gonna need to fabricate the whole downpipe. I should be able to find a flange though, right? Somehow, though, I'm struggling. It's a TD04HL13G volvo turbocharger.
I still haven't decided on a manifold, but I want something that won't force me to get rid of air conditioning. I'm probably going to cheap out on this too, I just want something that won't break and won't break the bank. And keep my A.C. blowing cold lol.
Old 05-18-2016, 10:29 PM
Dur Da Dur
hondur's Avatar
I think i'm gonna use 3" piping for the exhaust. I haven't decided on a muffler nor resonator, and i'm sure this is gonna suck while i'm n.a. but it's cool. It's a sub-100ci engine, i'm not worried about 'low-end torque'.
I figure i'm gonna design the downpipe so that it'l be a direct replacement for the header, same flange and all that.
Old 05-19-2016, 02:05 AM
Xanthias's Avatar
That flange looks awfully similar to the tdo4 off of a mitsu 3000 gt, maybe find that manifold from a local wrecker and cut the flange off and then weld that to some steel piping and then slowly step it up to at least 2.5 inch for the rest, insert some flex pipe and then after that throw the cat on it with a flange of some sorts
Old 05-19-2016, 02:16 AM
Dur Da Dur
hondur's Avatar
I wonder if I would find a rarer turbo trim mitsubishi or a volvo that's broke first. The turbo came off a volvo something Idk. I'd rather just have a flange mailed to my house than have to go do stuff like bring a sawzall to a junk yard.
Old 05-19-2016, 02:18 AM
Xanthias's Avatar
there were 3 at my local japanese wrecker but im not sure what your situation is, I know if it was me and my buddy we would have it all done in the course of a day but he has a welder idk what access you have
Old 05-19-2016, 02:22 AM
Dur Da Dur
hondur's Avatar
I can weld stuff, plasma cut a flange or just cut a junkyard car's downpipe in half but honestly I just really want something that bolts up to this mailed to my house
Xanthias's Avatar
Also a quick search told me that the 13G mainly came on mitsu 3000 gt/ dodge stealth tt, while the 13T came on a volvo as well as the 13C, so your turbo is the same as the one I have in my basement
Old 05-19-2016, 02:23 AM
Dur Da Dur
hondur's Avatar
Bruh it says volvo on it and they're different
Old 05-19-2016, 02:28 AM
Dur Da Dur
hondur's Avatar
does anyone know what the technical code name for this dumb f'ing flange is?
Old 05-19-2016, 02:36 AM
Xanthias's Avatar
3000GT VR4 Mitsubishi Turbo Inlet Flange SET TD04 9B TD 04 TDO4HL 19T 1 2" CNC | eBay
Measure the diameter on the turbo and see if it matches the size of this "bruh"
Old 05-19-2016, 02:37 AM
Xanthias's Avatar
Or this
T3 Turbo Discharge Flange Internal Wastegate 3 Bolt 2 25"ID SS304 NEW | eBay
Old 05-19-2016, 03:27 AM
Dur Da Dur
hondur's Avatar
Tbh neither of em really look right, look at this weird raised bit on the discharge side of the turbine
And the bit that connects to the manifold is weird too it isn't a normal T3 flange either.
Old 05-19-2016, 03:31 AM
Dur Da Dur
hondur's Avatar
The spacing between the studs all appear to be 3 1/4
Old 05-19-2016, 03:58 AM
-Intl Steve Krew
Caoboy's Avatar
Use MM not IN
Old 05-19-2016, 04:11 AM
Dur Da Dur
hondur's Avatar
You're right I forgot im pretending to be Japanese right now.
I should go find a bore gauge
Old 05-19-2016, 05:11 AM
Dur Da Dur
hondur's Avatar
manifold gasket
8642450
down pipe gasket
1275549
i started looking up stuff based on the car instead of the turbo and now i'm getting somewhere.
Old 05-19-2016, 05:20 AM
Dur Da Dur
hondur's Avatar
look guys i found it
all i had to do was enter the correct term into google. "s70 turbo flange"
Old 05-19-2016, 05:23 AM
Dur Da Dur
hondur's Avatar
i found the other thingy too!
And now, with these informations combined with the fact that my girlfriend taught me chinese, i'm gonna buy both of these for seven ninety nine after shipping.
Old 05-19-2016, 05:33 AM
Man U FTW
Schister66's Avatar
My only thoughts on this are - you dont need a 3" exhaust for 240whp...2.5" would be fine. And at 240whp on a stock D, you're flirting with rod-bending levels of power.
Old 05-19-2016, 05:44 AM
Dur Da Dur
hondur's Avatar
Yeah I know, I'm probably gonna keep it around 200whp unless I get some rods and pistons.
Thanks for the input on the piping size. Does anyone figure anything about the cat off the V6 accord?
Old 05-19-2016, 08:07 AM
-Intl Steve Krew
Caoboy's Avatar
Why a cat? It's going to hinder flow and you'll probably foul it anyways.
Old 05-19-2016, 09:42 AM
Dur Da Dur
hondur's Avatar
I can't use a cat for break in tho, I added lead or something to the break in oil and it says it'l ruin the cat if I have one hooked up. After a thousand miles of n.a and after it's turbo'd I want a cat tho. Why is that hard for ppl to understand? My car is gonna run clean.
Quick Reply: You guys wanna help me design my exhaust?
