What clutch for turboed D16Z6/Y8
Say I wanted to turbocharge a SOHC VTEC, or even just a SOHC Civic motor, and run low boost at first(about 7psi), what clutch would you guys reccommend?
What clutch then for high boost?
Thanks.
Thanks.
Re: What clutch for turboed D16Z6/Y8 (Breakdancer)
Thanks.
Thanks.
Re: What clutch for turboed D16Z6/Y8 (wanabecivicex)
ACT Xtreme....was using this on street and track...worked well in both situations. Had no problem w/ this clutch and my MT slicks... ACT
Re: What clutch for turboed D16Z6/Y8 (98civicEX)
Look into the Action Clutchs.. From the reviews they are nice units.
Talk to Rocket, and also look for his clutch review on here.
Re: What clutch for turboed D16Z6/Y8 (Midwestrider)
I had a Centerforce dual fiction,loved the pedal feel but once i started boosting higher it started slipping like around 10-12psi.i replaced it with a ACT
Re: What clutch for turboed D16Z6/Y8 (inspyral)
I know of 2 ppl w/ si's that use the Clutchmaster Stg 3 clutch.
One is boosted w/ greddy kit, the other is a n/a si...
I have drove the n/a si and took me a second or two to adjust to the clutch. okay to me..
I was looking at the stg 3 but gonna try the Action unit.
i have Extreme PP with Action 6 Puck
the PP is extremely stiff, but i am used to it now
so far so good for everything
but i found a strange sound once my clutch is engaged, need a mechanic to check it.. have no idea what sound it is
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: What clutch for turboed D16Z6/Y8 (VaporTrail)
NOT act HD. Get the Xtreme pressure plate and some sprung disc, if not an Action clutch.
Re: What clutch for turboed D16Z6/Y8 (KoRE)
i'll let you know how my action clutch holds up when i get it back....
Re: What clutch for turboed D16Z6/Y8 (ion_four)
Any of you guys with these ceramic or kevlar puck clutches had them last a long time like two years or something???? My ceramic clutch chewed through my flywheel pressure plate and wore itself out in about 10 months!!! Is this just what you get when using puck style clutches on the street? i HAVE A BOOSTED ZC SOHC d16A6 only has 196whp @10psi so it nothing crazy. Any ideas on a clutch for me?
