what cha'll know about revhard/inline pro 3" AC compatible downpipes?>
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (project dc2)
were you able to get all 5 bolts in the downpipe? I can't see from that angle.
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">were you able to get all 5 bolts in the downpipe? I can't see from that angle.</TD></TR></TABLE>
nope only 4 out of the 5.
To get all five you would have to cut out a piece of the dp that you can't get the bolt into and out the downpipe on that bolt then bolt that one down with the others. If that makes since. I'll post pics of mine and what I'm talking about.
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (Hoosier Daddy)
I was waiting for one to come out. I like it, if you can get 5 bolts on there i will buy
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (redturbocivic)
i can maybe make it work with 5 bolts if ic rush the pipe some at the tip where the bolt is.
try that w/ a vband setup.. hehe... i was able to do it..
check it out..
https://honda-tech.com/zero...08946
Modified by 92HB_HB at 11:52 AM 5/5/2004
check it out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">just made this one today
muahhah it can be done. its a bitch though. </TD></TR></TABLE>
what would u sell them for
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (JDMDC4TURBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC4TURBO »</TD></TR><TR><TD CLASS="quote">
what would u sell them for </TD></TR></TABLE>
still deciding .. somehwere aroudn 240$ sihpped
n tot he other guy about hte vbamnd ac comaptible. mine still gots smooth bends. not cheated ones. but good job makin that dp.
we've both got our benefits.. hehe..
but mine can be taken off in about a fraction of the time urs can... i've gone ur route b4.. and man it was a pain to take off the DP.. that's why i opted to do my new one w/ a vband..
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (92HB_HB)
What does the V-band style look like?
BTW, that dp looks nice. So it seals fine with 4 out of 5 bolts? I would assume that's a yes.
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (slim9300)
what about the bolt to the manifold they are not all in! it looks like its crooked iup there and if you straighten it out will it still clear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 »</TD></TR><TR><TD CLASS="quote">BTW, that dp looks nice. So it seals fine with 4 out of 5 bolts? </TD></TR></TABLE>
Bump for an answer to this question
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (newgsrdriver)
Don't those bolts go thru the housing itself?
ie, no bolt = exhaust leak thru the hole?
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (MadCow the Transves
My POS DP has only 4 bolts and the muffler shop welded that hole to the DP so it was covered.
If you can make one for a reasonable price let me know cause I need one and I don't have A/C, but this is for my CRX(that is the only catch)
Halla back.
Halla back.
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (BLACKEG2)
im gonna straighten it out n check it. im sitll pretty positive itll work. if anything youll have to put a small dimple into it. and 4 outta 5 selas just fine. a lot of peopel just use 4 outta 5 cuz that last one is impossible to get to .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">im gonna straighten it out n check it. im sitll pretty positive itll work. if anything youll have to put a small dimple into it. and 4 outta 5 selas just fine. a lot of peopel just use 4 outta 5 cuz that last one is impossible to get to . </TD></TR></TABLE>
Would you be able to get all five bolts on a 3" dp if the hot side was on the passenger side? The bend wouldn't be as sharp. I have a 2.5" flared to a 3 inch dp with revhard mani and the compressor on the driver's side.
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (sneakypete)
if i use a flare right off the flange i can. it wont be under this topic " ac compatible" however. once i use that flare its gonna take up all the space imma need.
Re: what cha'll know about revhard/inline pro 3" AC compatible downpipes?> (blackANESE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">My POS DP has only 4 bolts and the muffler shop welded that hole to the DP so it was covered.
Halla back.</TD></TR></TABLE>
same here....take a look at these pictures and let me know if you can work with it.
http://www.we-todd-did-racing....D.jpg
Modified by jdm.ek at 6:05 AM 5/14/2004
