What Camshafts do you guy's use?
I'm trying to save up some money for cam's for my ls/vtec for boost. I've alwayse felt that they are too expensive but now I'm feeling like if I have the money and it is the "only" thing that I haven't done that I mise well. So I was wondering what you guy's are running for camshaft combinations on your boosted setup's. I'm working up to obtaining the 20+psi mark and looking for lots of power, but also lives a life on the street as well. So with the price not being toooo much of a determining factor.. I'd like to know what's tried and proven for you guys..? I would assume this is the right thread in the FI but if not sorry about that. Thanks guy's
Re: (randys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shanerv »</TD></TR><TR><TD CLASS="quote">dude randy's.... 630hp B16 with stock internals...? Is that right/if so HOW?!</TD></TR></TABLE>
Anything is possible, dont expect it to last 10 passes down the strip or anything..... for another freakish B16
How is it possible??? I am guessing 1000cc Injectors and 30+psi, correct?
Mr. Badwrench
Re: What Camshafts do you guy's use? (shanerv)
i have been having good luck with my gsr's, made 520 at 27 psi with relatively low timming.
switching to CTR's when i build my gsr.
Re: (randys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randys »</TD></TR><TR><TD CLASS="quote">you are correct!! and it only lasted 4 and a burn out, not 10. ha!</TD></TR></TABLE>
Hehe
Hehe
Re: (12SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV »</TD></TR><TR><TD CLASS="quote">itr cams</TD></TR></TABLE>
Re: (D-tuned)
Following on this line of thought - ie get better cams for more power,
Do you need to change the springs and retainers when going to these aftermarket cams and I would assume you would with the type R ones.
So the cost starts getting up there
Would it be better to go down the headwork line and get bigger valves and a bit of head work instead of doing the cams?
Which would give you better results... or is it better to do both at the same time matching the cams to the headwork? (i know this means more money but still interested)
Re: What Camshafts do you guy's use? (pitbullracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">im considering the Mazworx V1 cams</TD></TR></TABLE>
Same here, or the blox b
Re: What Camshafts do you guy's use? (Mugencrxsir1)
I'm currently running the JG Engine Dynamic valvetrain ie. Dual Springs and Titanium Retainers in my head and wasn't sure if I'd have to RE-buy the valve train for what ever cams I buy from that company? Because if so... that'd suck to repay again...!
Re: What Camshafts do you guy's use? (4rc-fed)
So Blox B's make more power that ITR? Is there any dyno sheets out there to show where power was gained and lost?
Re: What Camshafts do you guy's use? (96 GSR-T)
hey i was just wondering if the skunk2 pro series stage 1 cams would be good for a very mild turbo build. i just bought the cams thinkin i would stay na but decided to go turbo and dont wanna buy new cams again. i was wonderin of the overlap is low enough for a turbo setup
Re: What Camshafts do you guy's use? (88crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx »</TD></TR><TR><TD CLASS="quote">hey i was just wondering if the skunk2 pro series stage 1 cams would be good for a very mild turbo build. i just bought the cams thinkin i would stay na but decided to go turbo and dont wanna buy new cams again. i was wonderin of the overlap is low enough for a turbo setup</TD></TR></TABLE>
Quoting stuff you read about overlap? For a mild setup just use ITR/CTR
the thing about itr cams is that i just dont want to but new cams im low on cash and i already have the skunk2 installed
brnvle
23
04-26-2007 08:29 AM
