What is the best turbo for a b18c bottom and b16 top
450-500 hp turbo project on a b18c and b16 head
I am going to turbocharged my car,cant make up my mind what turbo is best for me i am thinking to get a t3/t4 E hybrid 0.50 0.63 57trim stage 3 turbin wheel,is it the best for me or a ball bearing series.What is the difference between a ball bearing turbo and a hybrid? if ball bearing is better what ball bearing turbo should i go for?
Modified by sky88 at 7:21 PM 5/14/2004
Modified by sky88 at 7:22 PM 5/14/2004
Re: What is the best turbo for a b18c bottom and b16 top (sky88)
titan61
great spool time - plenty of room to grow on but works great on mildly modified engines
Re: What is the best turbo for a b18c bottom and b16 top (DRAGLS)
that is top secret information - you dont' need to know how it makes power - just that it makes power
Re: What is the best turbo for a b18c bottom and b16 top (TitanMotorsports.com)
you mean a titan 61 is better that a t03 04 e hybrid turbo 57 trim 0.63 0.50 stage 3?
in all honesty i really have no idea if it is necessarily better, this is the first turbo we have even tried on the car and has had fantastic results - worked great when the engine was still 1.6l - at 8 psi made 275 hp - and works great on our new 2.0l engine
if i am thinking to have a 450 -500 hp what should i do to my engine my technician told me impossible the most i can get is about 380 but i really want a 450 -500 hp with a t3 t04 e hybrid 57 trim 0.50 0.63 stage 3 should be possible.I gues just some engine upgrade plaese let me know in detail what i should do to fullfill my dream this is my 1st turbo project
do some research on other people's setups with the power level you are looking to get and you can get a pretty good idea of what needs to be done - off the shelf parts will get you to your goal - and tuning will be the big key in making it reliable - but if you won't be drag racing the car a whole lot and then i wouldn't even worry about getting to 400-500 - 350-375 is pretty impressive in a street car and you can get relatively decent traction still
i am new can u please let me know where to do reseach.According to my technician my block will be melted if i want a 450-500 hp engine even with block guard i am using a 83mm piston please let me know in detail what shd i do to have a 450-500 hp thanks
How much is a titan 61?
04-07-2012 08:37 PM
