what bearings should i run?
its an h22a1, and the machine shop is also a parts place, and they said to run their bearings, for the mains and rods...should i , or should i use honda ones.
also where can i get a high volume oil pump and water pump?
-vinny
-vinny
Re: what bearings should i run? (93ludevtec)
use stock if you can get it, they're backordered forever...or use ACL, they're bad ***, and they fit really really well.....just like stock..
why would you need a hi volume water pump and oil pump, the amount of oil and coolant you;re running is still the same...use water wetter if you want....
stan
stan
i just like to over prepare then under prepare, seems to work better,
oil pump....same story...many Pro racers that I know personally runs stock pumps, don't underestimate the stock OEM parts...they can handle more than you think...
stan
SpoolnG2
04-01-2008 06:15 PM
94lsboost
12-14-2003 11:08 AM
