wft?? garrett turbo blown after only 300 miles??
added pcv setup up, no more smoke
Modified by malubawla at 10:43 PM 7/5/2007 |
Is it a brand new turbo?
Re: (TurboElements.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com »</TD></TR><TR><TD CLASS="quote">WAS it a brand new turbo?</TD></TR></TABLE>
^^^^ Good Point.
Re: wft?? garrett turbo blown after only 300 miles?? (malubawla)
were you running an oil restrictor?
Re: wft?? garrett turbo blown after only 300 miles?? (. a d a m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m »</TD></TR><TR><TD CLASS="quote">were you running an oil restrictor?</TD></TR></TABLE>
What size feed line are you running? Also have you done a compression test on your motor to make sure it is fine? Alot of people blow their oil seals because they use too big of a feed line, dunno why they even make the -4 lines, use a -3 and a restrictor if need be. https://honda-tech.com/forums/images/smilies/emthup.gif Also run a good crankcase ventilation/catch can set up on the car
Re: (Boostfed.com)
i think i had a combination of problems....i had no oil restricter, the turbo was 3000 miles used supposedly "mint", and i installed a oil catch can setup about 10 miles before the turbo blew.....i guess its time to rebuild and order a restrictor.....you learn from your mistakes
Re: (malubawla)
the oil supply line is -3an.....can you suggest a good oil restrictor for me to buy? i ordered a rebuild kit from gpopshop.com
Re: (malubawla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla »</TD></TR><TR><TD CLASS="quote">the oil supply line is -3an.....can you suggest a good oil restrictor for me to buy? i ordered a rebuild kit from gpopshop.com</TD></TR></TABLE>
I can sell you a restrictor for like $17-$18 shipped http://www.atpturbo.com/Merchant2/gr.../oil022-01.jpg |
Re: (Boostfed.com)
send me your paypal addy....also, whats the proper way to set up a oil catch can on a d-series?
Re: (malubawla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla »</TD></TR><TR><TD CLASS="quote">send me your paypal addy....also, whats the proper way to set up a oil catch can on a d-series?</TD></TR></TABLE>
Paypal@boostfed.com |
Re: (malubawla)
dont rebuild the turbo dont even take it apart!
try putting the restrictor in and see if it leaks you should be ok.. |
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">
Paypal@boostfed.com </TD></TR></TABLE> send me a pm with all the info and total |
Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 »</TD></TR><TR><TD CLASS="quote">dont rebuild the turbo dont even take it apart!
try putting the restrictor in and see if it leaks you should be ok..</TD></TR></TABLE> thanks i'll try it...also, i think my catch can is installed wrong |
Ive heard of the Garrett turbos going like this before. For instance my buddys spec was arround 150 miles on the new motor and turbo setup one nigh we took it out to do some more highway break in and suddenly smelled something burning. We pull over and open the hood the turbo was glowing red ! But being the good people that they are, Garrett replaced it free of charge although there were questions about oil starvation and other things that may have caused this.
About this pil restrictor though, would this cause a turbo to burn oil out the exhaust? a little bit of greyish smoke here and now possibly? |
Re: (gorilla unit 33)
bump for more info
this is why I never buy used parts, every thin you buy that is turbo related has only "<1k miles" and when you get it, it breaks. i would def try the restrictor before you rebuild.
And your better off to send the turbo in for a rebuild to make sure it is 100% balanced.
I ran my brand new garrett t3/t4 last year without a restrictor all year... daily driven and track raced... never had a problem...
but id try a restrictor if i was u |
lol @ it couldnt possibly just be a bad Garrett
Re: (Blind_Attack)
it is used so anything is possible... worth trying some simple things though before you decide to take it off and send it in for a rebuild. it may not need it. could just be too much oil pressure is pushing oil past the seals, in which case an oil restrictor will fix it cheaply.
Re: (malubawla)
thanks i'll try it...also, i think my catch can is installed wrong</TD></TR></TABLE> im pretty sur eyou did do it wrong as well, you probably have a few hoses going into and under ventilated can, or a NON ventilated can huh? seen this before and that person did the same thing, 3 turbos gone https://honda-tech.com/forums/images...s/emthdown.gif |
sell me the turbine housing.
Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly »</TD></TR><TR><TD CLASS="quote">sell me the turbine housing.</TD></TR></TABLE>
asshat..... thanks for everyones help, i'm gonna re-route my catch can setup and install the restrictor.....i'll let ya know how it goes.. |
