Well I finally got it on paper... ouch!
I took a trip to CFM today after work and spoke to the man himself, Forrest, about my build up. It all comes down to $2900 for everything w/o sleeving (another $550-750), and this includes labor and head work. So how does this all sound to you guys? I know it's alot, but SFP was about $2700 w/o labor so I actually think I'm gonna come out pleanty better with CFM.
Another question.. how importnant is it that I do the head at the same time as everything else? I was quoted at:
$320 for oversized SS Ferrea valves
$250 for springs and retainers
$350 for the PnP and relapping/sealing the valve stems
That's a total of about $920 I can save if I do at a later date, or is it imperitive that I do the head with the block?? Let me know what you fellas think
Re: Well I finally got it on paper... ouch! (VTC_CiViC)
You can hold up on PnP if you like, but definitly do the valves and springs and retainers. What kind of springs and retainers are they giving you for $250? Pnp would allow more air to flow through, its really up to you. I say you might as well do it for an extra $350. Do it right the first time!!
Re: Well I finally got it on paper... ouch! (SO3Burner)
What youre getting for $2900?
JE 9.0:1 77mm pistons w/ rings
ARP harware
All new seals and bearings throughout
Water pump
Oil pump
PnP head
new valve springs and titanium retainers
valves re lapped and sealed
oversized Ferrea SS valves
Intake mani matching to head and 60mm B-series TB
I have to decide with whom to sleeve it all, though I think it'll be between Mesa balacing (they do lots of race engines, used to be SFP's #1 choice before they switch to Darton), or GE sleeves.
well I added the prices that I have paid for or been quoted on these parts (very similar to my B18c1 set up) and it came out very close to the sfp cost, actually I got $2900 no labor.
I dont know how they can do it for $2700 with labor ???? That is good price considering labor is included.
Check out www.rpmrons.com.
They are building up my 4G63 and Ron really knows what he's talking about. Give him a call and be a believer.
This guy is building a monster for me. Ross 9.0:1 forged pistons w/wristpins and rings, , complete balance/blueprint/index/polish of my rotating assembly, R&R of the head with Manley 1mm over SS valves, new valve guides, decking, all the usual magnaflux/honing/boring/beadblasting/painting of the block and head, and complete reassembly with new timing components, all for $2400 with parts.
And here is the best part of all:
12 month/ friggin' 12,000 mile warranty on all of his labor.
Re: Well I finally got it on paper... ouch! (Hammer)
Right now my biggest concern is sleeving. I know GE has made a name for themselves, but that's an extra $750 + S/H, whereas both SFP and CFM use a select local machineist to do their sleeving, and from what I've been told, they're excellent blocks too.. I'm going to call and verify that the $550 I was quoted to sleeve my block was indeed with stronger aftermarket iron sleeves and not OEM replacements.. if it's good, I think Forrest pretty much sold me on doing it there. I'll let you guys know
$2900 sounds good for what you are getting.
I would not go with the Ferrera valves, they are overpriced generally.
As far as the PnP on the head, find out who is doing it for CFM, but I know Forrest does headwork very well, don't know about the rest, but the headwork is good (He does SFP's work right ?) as long as you get a good price on the headwork, DO IT, mild, but do it you will already have the head just about bare and you are gonna put a new top end gasket/seal kit anyways, so why not just avoid future downtime and have it done while the head's off and dissasembled !
Is the price of the valve job included in the $2900 ? Going oversized right ?
If this is going to be a daily driver, don't go all out with the 5 angle, keep it at 3 !
Re: Well I finally got it on paper... ouch! (X2BOARD)
Yea the $2900 includes the headwork and all head components. So I gather this is a good price then? Sounds good. There were two interesting points to the build tha Forrest and Jarred brought out to me yesterday that I wanted to ask you guys your opinion:
#1- They encouraged me to step up to a 77mm bore vs. the stock 75mm. I'm sure there's enough room in the block for the increase, but with this create any problems with matching the combustion chamber to the block opening?
#2- They also encouranged me to use a blockguard even after I sleeve. I was always under the impression that going with stronger aftermarket sleeves would relive you of having to deal with blockguards and their inherit cooling problems. Has anybody heard of going with a BG and sleeves in a 350whp engine?
2) At that anticipated Hp, hell yeah you should get a BG. At least get one tapped in if you are not going to sleeve now. If you are going to hone the block (you will do it after sleeving) You prolly want to get your blockguard welded in when you sleeve, that would be the best way.
I have heard good things about the STR blockguard (superior cooling).
Why not just remove your thermostat to keep the motor running cool all of the time ?
The thermo is not a good thing to remove. If you engine is cooled too much it will effect not only horsepower but emissions and gas milage as well!
VTC: If you are going with the head work, as for some brass valve guides as well!! No point in getting SS valves if they are still rubbing on the stock guides.
Re: Well I finally got it on paper... ouch! (Spade)
As far as keeping 'too cool' without a thermostat.... I don't think VTC is running all motor.... turbo cars on the other hand get HOT, all of the time. The no thermo should work like a charm.... especially in the Miami heat !
Spade - Who is just starting to learn about turbocharged engines.
No real need in brass guides, they're gonna get filed down on the exhaust ports anyways....
Did you or are you going to check www.rpmrons.com ?
B18C1 swap alone will cost me $3k easy.. w/o install
Re: Well I finally got it on paper... ouch! (KhRoNiX)
Good luck with Forrest because I know that I have not had the best experiences with him AT ALL.
X2BOARD- Dude I spoke to Laz at Mesa, really cool guy I'm pretty much set on sleeving with him ($600), thanks for the reccomendation
Re: Well I finally got it on paper... ouch! (98civicEX)
that should haulass. I remember my old built d16z6 with 18psi...ooohhh yaaa it really hauled ***. Lots of fun!!
With that setup and sleeves you should beable to boost that to 25-30psi...hhaa...the promise land!
liam
liam
I hear ya meng... I'm not 100% sold on CFM yet though I'm leaning awfully close to it already.
P.S. I gotta put in my $0.02, I gotta go with Kronix on this... I'm not too hot on Forrest as far as building your motor. I have heard a couple of stories (and seen one too) that involve smoking... (and not the chronic either). Keep on the look out.
