Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Welding (https://honda-tech.com/forums/forced-induction-16/welding-297070/)
SlowB16 Oct 3, 2002 01:22 PM
Welding
For all you people that know how to weld, hwo did you learn? Just trial and error or did you take some sort of class? I want to be able to weld simple stuff like body panels and piping of different types. Where would a good resource for a welding machine and how-to equipment be? Thanks in advance. - Matt
BigMoose Oct 3, 2002 02:44 PM
Re: Welding (SlowB16)
Matt I learned stick by trial and error. I welded a lot of rusty VW bug panels back in the 70's with a buzz box I rewound for lower current and higher open circuit voltage. Read a lot of books, mostly from Lincoln Electric. Their web site is a treasure of tips now.
When I went to TIG it was trial and error, but I got hung up on some aluminum problems and had to search out a pro at work to give me a few tips from his experience. Aluminum is a real art, I wonder if I will ever get the hang of it.
Also had a pro help me with my first TIG on cast iron, then from there cast was a snap with TIG.
Oxy-acetylene is a snap, safety and protection from flashbacks is the only real issue there.
Regards,
BigMoose
Brad Oct 3, 2002 03:08 PM
I'm still a novice at welding, but I learned by trial and error. I started with intercooler pipes, then eventually made my own exhaust and downpipe. I wanted to take a class at my local community college, but they didn't offer any. I just bought a welder at home depot and went at it. If you want to try it there are places that rent welders and there's some info on the internet.
Brad
legendboy Oct 3, 2002 03:32 PM
Re: Welding (Brad)
Practice, hours and hours of practice!
apexii Oct 3, 2002 03:39 PM
Re: Welding (Brad)
Brad
I did the exact same thing, with a lincoln weldpak 155. http://images.zeroforum.com/smile/emthup.gif
[Modified by apexii, 7:40 PM 10/3/2002]
SlowB16 Oct 3, 2002 04:45 PM
Re: Welding (apexii)
So is something like that good enough for body work?
SlowB16 Oct 3, 2002 04:49 PM
So is the MIG just an attachment on a standard wire feed welder? I was looking on ebay and it looks like about 200-300 for a used lincoln weldpak is what I am going to be paying, does that seem right?
c1hatch Oct 3, 2002 04:52 PM
welding body work is a totlly different story than just plain welding. You are gunna be welding mostly thin 22 gauge steel. you would haev to jump around keeping it as cool as possible not to warp the panels.
practice-practice.
i think the best way to practice is to weld coupons (2"x4" sheets of metal) together.
RavenGTi Oct 3, 2002 05:17 PM
a MIG is a wire feed that uses an inert gas as shielding, as opposed to flux core wire.
the best way to learn is to be instructed by someone with skills and experience. that is not to say that you cant get good at it by trial and error. i havent found a place that can teach me, so i am stuck learning on my own.
the majority of it is just confidence. you know what has to happen, so just do it. then you learn what situations will warrant certain adjustments.
dustin Oct 3, 2002 07:52 PM
Re: Welding (c1hatch)
practice-practice.
I started with TIG and it's not that hard.
Very thin steel like that is a lot easier with a pulser (I have a Miller Maxstar 200DX). It melts the metal locally instead of heating the entire area and warping it. You still have to be careful though.
SlowB16 Oct 3, 2002 10:19 PM
Re: Welding (dustin)
Can body work be done with a mig or plain wire feed? Or do you need TIG because I cant afford one of those....
dustin Oct 3, 2002 10:23 PM
Yes but like any bodywork welding you're gonna have to grind it down flat http://images.zeroforum.com/smile/emsmile.gif
SlowB16 Oct 4, 2002 05:26 PM
Yeah I figured that, but I just wanted to know if the welds would be strong enough. Thanks alot!!!!
