Wastegate not centered on manifold? does it matter
Old 11-17-2011, 08:23 AM
SiRCiviC94's Avatar
Default Wastegate not centered on manifold? does it matter
I seen various log manifolds all I want to know is if there is any issues if it mounts to the cylinder 1-2 exhaust ports instead of being centered in the middle.ill get pics if needed most of what i see is centered
Old 11-17-2011, 08:35 AM
kyden's Avatar
Default Re: Wastegate not centered on manifold? does it matter
probably gonna run into a boost creep issue.
Old 11-17-2011, 09:05 AM
TiAL's Avatar
yes that is a problem
Old 11-17-2011, 10:49 AM
SiRCiviC94's Avatar
k well that worries me a lot, even using a tial wastegate or anything for that matter to correct the problem? I dont want to step on it and find out there needs to be confidence its going to work properly. heres a pic, its off to the side like im saying
similar cars set up
Old 11-17-2011, 10:57 AM
Retired Moderator
EsotericImage's Avatar
well, is it a cast mani on the #1 or a fabbed log mani?
Old 11-17-2011, 11:08 AM
SovXietday's Avatar
Even the best wastegates can only control the amount of exhaust that they see. Those log manifolds force the wastegate to only gate the exhaust out of a single runner and allowing the other three runners to run free. Not to mention the exhaust has to make a hard 90 to get in the wastegate.
Those cast log manifolds literally rely solely on heavy backpressure to allow the wastegate to regulate exhaust pressure correctly.
Old 11-17-2011, 11:43 AM
SiRCiviC94's Avatar
I didnt really understand them, looking at it thats pretty hektic. so excess boost air is going to be dumped right into my down pipe but has that crazy 90bend. I could try it I guess and watch for boost creep
Also the exhaust will have lots of back pressure its a 2.5" straight with jdm gsr axleback but might go with a stealth instead. dp is 3" modding to 2.5" pipes
yes second pic is home made but similar.
dagle
02-09-2008 12:51 PM
IntegraMastaz
02-08-2006 09:33 AM
cj355
10-08-2005 04:37 PM
ghettochild
09-19-2004 07:21 PM
rota426
05-13-2003 09:21 AM
Quick Reply: Wastegate not centered on manifold? does it matter
