Wastegate, downpipe gasket. wast gate down pipe HELP!!
What do you guys recommend. I have a tial 38 mm waste gate. I need both sides of the waste gate sealed. I have a 3 inch down pipe and if they made a gasket for this five bolt design I would only have line a 1/16 inch of gasket in some areas. A shop recommended high temp silicone. Is this what I should do or are there alternatives? If silicone, any specific ones that have worked for you?
There are gasket for the 38mm wastegate and the t3 five bolt gasket. I know because I seen it before. But high temp silcone works for me too. I had a leak where the downpipe connect to the turbo and I put high temp silicone all around it. It fixed it so I can't complain about it. Just go to any auto parts store and grab any high temp silicone.
Re: (inspyral)
nice pic from RRE. heres the link for the OP if he really wants a dp gasket. http://www.roadraceengineering...s.htm
i ♥ my honda
Global Mod
Global Mod
Re: Wastegate, downpipe gasket. wast gate down pipe HELP!! (boostedteg4dr)
WG= Don't need a gasket
DP= I just use copper spray
They do make gaskets for both though and I know ATP has them.
Re: Wastegate, downpipe gasket. wast gate down pipe HELP!! (White Smoke)
make sure the mating surfaces are flat and tighten the hell out of the nuts and call it a day. I never use wastegate of downpipe gaskets without issue.
Re: Wastegate, downpipe gasket. wast gate down pipe HELP!! (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">make sure the mating surfaces are flat and tighten the hell out of the nuts and call it a day. I never use wastegate of downpipe gaskets without issue.</TD></TR></TABLE>
x2. i always hit the surfaces with a belt sander, and make sure everything is tight. the only gasket i run in my street car is head>manifold. the other gaskets just cause problems when they blow.
