Wastegate actuator spring...
My wastegate actuator has an internal spring for 7psi. I'm going to be controlling boost with an AVC-R, now if I understand my theory correctly, I can run as much boost as I want with the AVC-R hooked up, but can't go less than 7psi... right?
Re: Wastegate actuator spring... (CycloneBlue_1.6EL)
come on...
I think you pretty much summed it up. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Wastegate actuator spring... (Mario.)
sweet
| All times are GMT -8. The time now is 09:13 PM. |
