want to make 375 to 400hp on this set up is it possible
2000 milano red gsr
b18c1
t3-t4 60-1 turbo
stock drag turbo kit
low comp je pistons
eagle rods
jg manifold
rc 750 injectors/fuel rail
hondata s100 boost
walboro fuel pump
rs slevees
arp head/main bolts
Is my goal resonable any info will be cool thanks
Modified by tmkpres at 12:30 AM 3/16/2004
Re: want to make 375 to 400hp on this set up is it possible (tmkpres)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmkpres »</TD></TR><TR><TD CLASS="quote">t3-t4 60-1 turbo
low comp je pistons
eagle rods
jg manifold
hondata s100 boost
walboro fuel pump
rs slevees
arp head/main bolts
Is my goal resonable any info will be cool thanks</TD></TR></TABLE>
on what motor and how much boost? well i guess it doesn't matter since you're already sleeved. anyway, the only problem or restriction i would see with making that much power with a drag kit is the IC piping and the small *** intercooler. not saying it's not possible because i've seen people do it, but as i said, it's a restriction.
low comp je pistons
eagle rods
jg manifold
hondata s100 boost
walboro fuel pump
rs slevees
arp head/main bolts
Re: want to make 375 to 400hp on this set up is it possible (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">the 750 injectors will support 400whp?</TD></TR></TABLE>
750 can support 400whp. my buddy tyler made 400.2whp on his turbo'd LS with just RC550's. it's all in the tune along with fuel pressure.
Re: want to make 375 to 400hp on this set up is it possible (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">
on what motor and how much boost? well i guess it doesn't matter since you're already sleeved. anyway, the only problem or restriction i would see with making that much power with a drag kit is the IC piping and the small *** intercooler. not saying it's not possible because i've seen people do it, but as i said, it's a restriction.</TD></TR></TABLE>
can you explain the restriction with the IC in detail? whats the problem on making x HP with a intercooler? the piping diameeter or what?
Thanks
Malte.
Thanks
Malte.
Re: want to make 375 to 400hp on this set up is it possible (mrx)
the problem with the intercooler restriction is because it will become heatsoaked and stop doing its job, also the actual size of the inlets and piping wont flow enough air for the higher horsepower levels.
Re: want to make 375 to 400hp on this set up is it possible (93h22a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a4 »</TD></TR><TR><TD CLASS="quote">the problem with the intercooler restriction is because it will become heatsoaked and stop doing its job, also the actual size of the inlets and piping wont flow enough air for the higher horsepower levels.</TD></TR></TABLE>
damn 93h22a4 beat me to it. but yeah, what he said. a small intercooler will not be able to cool efficiently the air needed to make the power desired and the small 2" piping will also limit the amount of air flow. so basically i'm just saying what 93h22a4 just said.
Wow 550 aren't really safe making that much hp. At 80% duty cycle the can only produce around 346
That pretty much sums it up!
