Want to do minor upgrade on motor to be safer @ 250whp
Right now it's totally stock motors
runnig t3 60 trim 10 psi on GSR, producing 250whp. Tuned AFR 11.5:1 properly and ignition is 19 deg hi-cam. Hopefully conservative enough.
I don't have money for building motor yet, so is there any minor upgrade I can do to "strengthen" my motor a bit? This is a daily driven car so I don't wanna blow my baby
1. Thicker headgasket - lower compression, then raise to 12psi (I heard this is not a good idea)
2. ARP headstuds
3. Blockguard
Modified by elpiar at 6:26 PM 10/28/2005
2. ARP headstuds
3. Blockguard
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Want to do minor upgrade on motor to be safer @ 250whp (elpiar)
It's fine as it is, IMO.
Just don't be a lead foot.
Who is Mr Robot?
Re: Want to do minor upgrade on motor to be safer @ 250whp (boostincoupe)
forget the blockgaurd... waste of money
the head studs are a good idea, your motor can take 12psi from the t3 as it sits now, just get it properly tuned
Re: Want to do minor upgrade on motor to be safer @ 250whp (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">forget the blockgaurd... waste of money
the head studs are a good idea, your motor can take 12psi from the t3 as it sits now, just get it properly tuned</TD></TR></TABLE>
What will the headstuds do? It will prevent the gasket from blowing but my limitations will still be the piston and rods right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar »</TD></TR><TR><TD CLASS="quote">
if you decide to get gasket, then might as well get headstuds - they are reusable so it pays back in the long run.. if you're not doing work youself, save the money for rebuild in the future.
Civicman86
04-01-2005 12:45 PM
