wanna verify what dsm injectors i have ? AND IF I GOTTA USE A RESISTOR BOX
the squirters are greenish color ad the tops have lil orange seals....also wanna know if i gotta use a resister box for these on my ls motor...
Re: wanna verify what dsm injectors i have ? AND IF I GOTTA USE A RESISTOR BOX (spoon20)
if they are blue topped injectors..you are ready to go. since they are peak and hold type injectors, yes you need the resistor box, as the hondas injector drivers are for saturated.
mike
mike
Re: wanna verify what dsm injectors i have ? AND IF I GOTTA USE A RESISTOR BOX (twkdCD595)
are resistor boxes still needed for the 2g ones i have...for my 98 ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon20 »</TD></TR><TR><TD CLASS="quote">are resistor boxes still needed for the 2g ones i have...for my 98 ls</TD></TR></TABLE>
yuppers, they are still peak and hold style
mike
mike
The easiest way to find out if you need the resistor box is to measure the resistance of the injector. If the injector measures between 2-6 ohms then you will need the resistor box and if the injector measures between 12-16 ohms you will not need it.
Re: (redxalien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redxalien »</TD></TR><TR><TD CLASS="quote">what about using dsm 450cc for an h23 in an 94 accord ?! i believe they are peak and hold . butt do i still need a resistor box ?!</TD></TR></TABLE>
they have one stock
they have one stock
