wanna turbo my D
wanna turbo my D
ok this is my first post in the forced induction forum. I have a d16z6 I wanna build for boost (econically) the motor had spun a bearing so I need to have the crank turned. I was thinkin about reusing the stock rods and pistons with just new piston rings (Ihaven't checked ring gap yet I need to) but I am not too concerned about this motor so I think I will just use them I plan on running about 10 ps1 of boost to.
What would be a good turbo for my sohc vtec that is capable of 10 psi I see all these different names and whatnot out there and I really am just lost on what I should be lookin for? I want to get a good turbo because I will probably use it on other motor after this one decides to take a hike
I was planning on gettin the johnnyracecar 6 inch intercooler because they are cheap and I heard not too hard to fit on my 91 crx. CAn someone recomend a wastegate that I use? I am gonna just get teh cheapest manifold that I can find. I also am going to make all of my IC piping and downpipe.
Also I want a cool sounding blow off valve (I know it is a little ricey but I love the turbo sound) what is a good one?
my main concern is engine management I think I am going to get some DSM 450 injectors but what should I do with my ECU(p28)....shoudl I just get it chipped? I think this is kinda cheap and I would rather have something tunable but I really have no understanding of uberdata or socketeing or even what socketeing means. I know I don't want to go cheap and just get an FMU but if someone could point me in the right direction I would be happy
Any other input on what I need or wha tI should do would be nice I think if I use my stock rods I will get arp rod bolts. But yeah I would love to hear from you guys and help me out and please don't just tell me to search thanx guys
CAsey
CAsey
Since you are going for an ecomonic build here is a list for ya. BTW 10psi on a larger turbo with pop you d16 pretty quick.
- Stock turbo w/ internal WG (Mit, Suby, Audi, VW, Ford)
- BMC turbo manifold
- DSM BOV
- Oil Lines
- DSM 450
- JRC 6'' FMIC
- Uberdata (its like 215 for a programed p28 and the stuff to make your own chips in the future)
- Hit your local exhaust shop for charge pipes
- Hit your local exhaust shop for the down pipe
- DSM BOV
- Oil Lines
- DSM 450
- JRC 6'' FMIC
