vtec or non vtec cometic headgasket on a gsr block
Old 10-22-2005, 12:10 PM
drjoe's Avatar
Default vtec or non vtec cometic headgasket on a gsr block
sleeved and bored to 84 mm with a type r head? i already searched tia
Old 10-23-2005, 08:55 AM
DaveF's Avatar
Default Re: vtec or non vtec cometic headgasket on a gsr block (drjoe)
wow.
you need a vtec gasket
Old 10-23-2005, 11:52 AM
onefstek's Avatar
Default Re: vtec or non vtec cometic headgasket on a gsr block (Dturbocivic)
you have a vtec eng. why would you want to use a non vtec head gasket.
just get one from golden eagle that is bored to 84mm.
Old 10-23-2005, 02:31 PM
m R g S r's Avatar
don't use the cometic one..no reason to.
if its sleeved you should have aftermarket pistons in there, and they should be lower compression already
Old 10-24-2005, 01:09 PM
street dreams's Avatar
Location: chillin in that city called queen creek, but homes the atl
Default Re: vtec or non vtec cometic headgasket on a gsr block (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">don't use the cometic one..no reason to.
if its sleeved you should have aftermarket pistons in there, and they should be lower compression already </TD></TR></TABLE>
that dosen't make any sense becuase u can get the cometi gasket in any size and bore
Old 10-25-2005, 09:20 AM
m R g S r's Avatar
Default Re: vtec or non vtec cometic headgasket on a gsr block (street dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams &raquo;</TD></TR><TR><TD CLASS="quote">
that dosen't make any sense becuase u can get the cometi gasket in any size and bore</TD></TR></TABLE>
WTF are you talking about......
Old 10-25-2005, 06:47 PM
earl's Avatar
if its sleeved you should have aftermarket pistons in there, and they should be lower compression already </TD></TR></TABLE>Cometics come in standard thickness as well as thicker gaskets.
blackcrx16
04-26-2008 12:12 PM
killacam661
09-11-2007 01:57 PM
96teggylsse
06-19-2007 09:26 PM
jgrogan
04-08-2007 07:19 AM
tunedek
02-26-2005 12:01 PM
Quick Reply: vtec or non vtec cometic headgasket on a gsr block
