Venting stock fuel tank after charcoal canister removal
#26
Re: Venting stock fuel tank after charcoal canister removal
Aren't they mounted on top of the fuel tank, though?
It's not a huge issue. I just don't like having an open line from my fuel tank going underneath my car. The Earl's fitting is a one way check valve. I'd prefer to have a 2 way check valve inline that's not so overly restrictive like the last one I bought. When pressure would build up to a certain point, the check valve would vent the tank just enough to relieve pressure. Makes sense, doesn't it?
#27
I dont think theres very much pressure comming out at any given time. So yeaah check valve may make it worse allowing pressure to build up unnecessarily.
I see where your going with this, just not an issue for me..... if anything Id put a filter on it and call it a day - dont fix something thats not broken / make it more complicated then it needs to be
#28
venting the gas tank with an actual vent will simply waste a ton of gas, and allow a potential explosion from the mass amounts of fuel vapors that can pour out on a hot day with low tank level and sloshing the fuel around from bumps. sealing the tank or using a check valve will obviously cause excessive tank pressures.
I ran an open line for a while, and on warmer days I could smell fuel practically nonstop, and gas mileage was crap. though it wasn't actual gas mileage, it was the sheer amount of fuel that would evaporate at all times, whether driving or parked.
my solution; I stuck a vinyl vacuum cap on the line and pricked it with a pin. problem solved. fuel loss is so low I'd claim zero loss from evaporation, but I know it does allow some out obviously. zero fuel smell. and tank pressure never exceeds 2psi, which is stock pressure anyhow. the pin ***** is key, because it keeps it sealed at near zero pressure, but allows vapors to flow out when tank pressures do start to accumulate
#29
#30
#32
mechanical barometric pressure guage. never saw anything higher than 140mBar above ambient pressure, even on a 95 degree day with under 1/4 tank driving down a super bumpy road. Colder days, with around half tank, smoother roads, never saw more than like 50mBar above ambient
#33
#34
#35
https://www.pegasusautoracing.com/pr...asp?RecID=8453
The hose I have on there now is 10an Aeroquip socketless, and I don't know how I can make it work with that.
#36
when i removed my canister i bent the vent line and cut it down so it went about half way up the fire wall then put a small breather filter on there, been running like this for a year now, but now thinking about running it in to my catchcan
aznlaoboi315
11-03-2008 01:26 PM
