Valve cover vent where to weld plugs on Rear
Old 09-22-2009, 11:31 AM
jetspeedz's Avatar
Default Valve cover vent where to weld plugs on Rear
I've seen quite a few threads with the PCV discussion and with vented valve covers and im going to run a custom setup. I want to run my lines to the rear of the valve cover. so my question is, is there a desired spot to weld -12AN fittings on the back? I plan on doing it somewhere behind the baffle but is there a preferred location you guys use to reduce the possibility of any oil coming out if any. Also the vented catch can wont have a drain back so it will vent and i plan on keep the black box but take the pcv out and put 2 3/4(-12) Barbs in there and run those up to the bottom of the catch can which will allow it to vent and if there is oil it will drain back hopefully without issues. If this does not work ill get the prelude plugs but for now id like your guys feedback
Thanks
Old 09-22-2009, 11:47 AM
YARO.'s Avatar
Default Re: Valve cover vent where to weld plugs on Rear
What motor is it?
Old 09-22-2009, 11:48 AM
jetspeedz's Avatar
b18c1 built for boost
Old 09-22-2009, 01:00 PM
Bailhatch's Avatar
The baffle runs all the way across, but doesn't go down the side of the cover in the rear. With a -12 you have just enough room to weld it above the baffle and that about the best you can do. I have one -12 off the back of my valve where the stock fitting was and two -8 lines draining to the galley plugs.
Old 09-22-2009, 01:08 PM
HamiltonRex's Avatar
put it where ever it fits, you can't really mess it up.
Old 09-22-2009, 03:27 PM
jetspeedz's Avatar
ok ill just put it along the back and make sure it is above the baffle.. thanks
Old 09-22-2009, 03:33 PM
radam's Avatar
Just watch for where ur fuel regulator mounts on the fuel rail. I made that mistake the first time.
Old 09-22-2009, 03:34 PM
jetspeedz's Avatar
got it thanks, yea i already was nervous if it would clear the tower with the aem fpr and it just did
mlstls1992
10-21-2014 10:21 PM
yyyktk1
08-10-2014 04:08 PM
sh!ft
Welding / Fabrication
08-12-2010 01:06 PM
vtec.dc2
05-06-2005 01:40 AM
Quick Reply: Valve cover vent where to weld plugs on Rear
