vaccume to wastegate MBC
do you need to have a small boost leak for air pressure to release in between your MBC and wastegate? whats the best way to do this if it is necessary?
Re: vaccume to wastegate MBC (Mr.Death)
when i say mbc, i mean air regulator with nipples instead of air quick connectors...
ive seen MBCs they sell and directions how to make a home made mbcs and they usually have a small pin hole to let the pressure bleed off..
poke a pin hole in the vaccume line? dont worry about it? drill one of the nipples?
does your mbc have a bleeder pin hole mr death? what is your setup like?
