URGENT: FJO Installation help
I am installing the FJO wideband kit w/ LCD display in my '99 integra LS and am stumped as to where to mount the controller and how to route the wiring through the firewall. These plugs are really big(too big for the firewall holes)! I am curious how you routed/mounted your FJO kits in an integra.
Thanks!
Matt
Thanks!
Matt
Re: URGENT: FJO Installation help (DeepSi)
I think I am going to do that for the LCD wiring, and just mount the controller in my engine bay so I don't have to mess with the O2 wiring. Thanks for the quick reply
Re: URGENT: FJO Installation help (mskibbz-T)
I temporary mounted the controller in the engine compartment and route the wires through the passenger window. The display unit is also temporay mounted on top of the steering column. I only use the WO2 unit for tuning purposes. Therefore, once the car is tuned, the unit is removed from the car.
You might want to cut the plug and run the wires through firewall and then resolder the wires.
Re: URGENT: FJO Installation help (boosted3g)
Jsut pull the pins on the plug run the wire through the firewall, then jsut put the pins in.
those plugs were a bitch to take out, in the end it worked nicely though..
[Modified by mskibbz-T, 5:21 AM 3/18/2003]
FourthGenHatch
09-02-2003 04:20 AM
