upgrade valve springs
Old 01-11-2007, 05:04 PM
swappedcx's Avatar
Default upgrade valve springs
Im not sure if I need to upgrade my valve train, so i figured I would get some input. I have the basic setup looking for 600whp. Lsvtec with 00 b16 head, gsr cams. Im running a sc61 so I have no need to rev higher than 8200-8500, because I figure I should have a decent powerband as is and probably wont make power higher than that.
I pulled the head apart tonight to get it hot tanked and replace the valve seals, but while im at it should I be ok with just replacing the valve springs, keepers, and retainers? I dont need to swap valves do I? I was just thinking of going with supertech or skunk2 for the spring setup.
Old 01-11-2007, 09:34 PM
morgan@synapse motorsport's Avatar
Default Re: upgrade valve springs (swappedcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swappedcx &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure if I need to upgrade my valve train, so i figured I would get some input. I have the basic setup looking for 600whp. Lsvtec with 00 b16 head, gsr cams. Im running a sc61 so I have no need to rev higher than 8200-8500, because I figure I should have a decent powerband as is and probably wont make power higher than that.
I pulled the head apart tonight to get it hot tanked and replace the valve seals, but while im at it should I be ok with just replacing the valve springs, keepers, and retainers? I dont need to swap valves do I? I was just thinking of going with supertech or skunk2 for the spring setup.</TD></TR></TABLE>
i would definately upgrade springs/retainers at that level. one less thing to worry about. if not to rev higher, just to stop any valve floating.
phelpsj2
01-03-2011 12:31 PM
killerpenguin21
11-21-2006 09:26 AM
daidilus
25
08-18-2006 08:21 AM
anthonylee29
04-19-2005 11:01 AM
9redsi9
03-15-2004 09:57 PM
Quick Reply: upgrade valve springs
