Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
#952
Re: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
Well.. I'm confused.. This is the inner workings of the Mishimoto catch can I recently received.. Am I missing something here?!
#954
Moderator
#959
You said it, not me. The company itself may not know the difference or see any harm in stating it works for both. Theoretically it might, but not as a practical matter in a real application, or at least not ideal. It just doesn't look as though it is a design to do both, that's all we're saying. If you want to battle with them over the nomenclature go ahead, do what you feel is in your best interest. But I mean, to me (and apparently also to Go-Auto,) it doesn't look like this would work in the way you need for your application.
#960
O.G. triple O.G.
ditch that CC and get something that actually works. You don't have to spend $$$ for one either.
https://www.ebay.com/itm/AN10-Polish...gAAOSwcB5cr-1o
https://www.ebay.com/itm/Oil-Breathe...ty!28107!US!-1
#961
^ what he said
If you're set on keeping that catch can you could just throw some steel wool in there and get creative with baffling, up to you if it's worth the trouble or not
Build is looking great, save the single jingle!
But in all honesty props for building the z6, it's turning out great. Glad to see you went with the action clutch, I was also concerned with other brands due to the springs not being completely enclosed or at least the area better reinforced. My clutch prior to the action 6 puck sprung clutch had the springs wobble out far enough to wear down the outside edges of my flywheel bolts. It made an interesting noise to say the least
Keep at it, in for updates
#962
#963
Go to your local hardware store, or find a piece of abs plastic you have laying around, hole saw it to the ID of the catch can drill a bunch of holes and secure it. Presto, one run-on sentence later and your problem is solved!
#964
I was thinking something along these lines. Some 2-3/4 SCH40 PVC and good ol' brillo would do the trick?
#965
Hellcat has arrived!
#967
O.G. triple O.G.
#969
In other news, my main relay has decided to give up on me. Sigh.. Tried to crank the car yesterday and nothing. Crank, no start. Fuel pump not priming. I could manually click the secondary relay on the pump line to prime it but other than that, nothing. I'm getting voltage at fuses 24, 31, and 18 respectively, at the relay plug, and fuel pressure will build and hold at the rail, and power at the ignition switch where and when I should have it.. So that's on the to-do list now. I'm sure it was on it's way out the door beforehand as I had some symptoms in the past, but it lasted, so I hadn't thought any more of it. The Honda temper tantrums continued; get a new item and some random ******* part I've either never had an issue with previously, that has lasted through thick and thin just ***** the bed. lol!
#970
O.G. triple O.G.
I'm in the same boat with mine. For the past few days, I've been trying to troubleshoot why my car is throwing a code #4 and 8. I even went to the extent of getting another good, used distributor. Same results...lower compression readings on all cylinders (150psi). Decided to remove the timing belt just for the hell of it. Bam...******' cam gear wobbling excessively. I could just swap the camshaft with another stock one but somehow or another, I think the "refurbished" head is messed up. I've had to clean out the oil orifice twice since I got the car dyno'd/tuned. FML....
#971
One thing I noticed today is that the main relay clicks when in K3 position but, the engine doesn't want to kick over. Just craaaannnnk, craaaaannnnk, craaaannnnk.. So, odd indeed. I hope it's not my ECU but, I've got a main relay coming regardless.
#972
Vibrant 12810 has arrived! This thing is MASSIVE compared to my other one. The fin density; no comparison.. I'll have more pics up later on.. Teaser for now!!
#974
Moderator
Anything is massive and more efficient than a CXRacing unit. Even the Treadstones would be nicer. Regardless, I'm just glad you're making progress and addressing the issue of better heat exchange... keep up the good work..
#975
I need to check valve lash again.. I'm past due on that and the top end is sounding a tad clicky.. Looks like I've got a coffee date in the morning with some valves..
