Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
Old 04-18-2019, 08:39 AM
  #651
Txdragon's Avatar
Default Re: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
Ordered the helicoil kit. Had to order the drill bit separately but, 42 and change was the total cost. "I need this 5 minutes ago" shipping was free! I will have that tomorrow to get this engine build back on track. Thanks for all the input here!
Old 04-18-2019, 10:17 AM
  #652
DaX
DaX's Avatar
Improvise. Adapt. Overcome!
Old 04-18-2019, 04:52 PM
  #653
NonovUrbizniz's Avatar
Oh man! Just read through. Good luck with the helicoil kit!
Old 04-19-2019, 07:04 PM
  #654
Txdragon's Avatar
Ooohhh yeeaahh.. I'm about to throw hands with this punk..
Old 04-19-2019, 07:14 PM
  #655
turboLScrx's Avatar
Old 04-19-2019, 08:51 PM
  #656
JRCivic1's Avatar
This was a head stud hole in the block that was damaged, right ?!?
Old 04-19-2019, 09:03 PM
  #657
Txdragon's Avatar
Yuppers
Old 04-20-2019, 09:20 PM
  #658
JRCivic1's Avatar
Is your installation tool long enough to get deep down into the block ???
Old 04-20-2019, 10:43 PM
  #659
Txdragon's Avatar
I don't think it will be an issue. *shrug* If, for any reason it does, I wouldn't be surprised. I would then turn all my hope for sanity over to Amazon and Ebay as potential ..
Old 04-22-2019, 04:19 AM
  #660
maxwellmercer's Avatar
I used the same kit, I had to weld an extension when I used it for the head studs.
Old 04-22-2019, 04:23 AM
  #661
Txdragon's Avatar
I watched a couple helicoil repair vids and it didn't seem that anyone else used an extension. I have a long 1/4" socket extension I can modify if need be, and of course if it'll fit. Lol!
Old 04-22-2019, 11:05 AM
  #662
Txdragon's Avatar
Can't see it very well but, it's done! Gonna let the thread lock cure and should be on the way. I didn't need an extension or anything, followed the directions to the letter. Drilled out old threads, but not too deep! Tapped until I felt resistance, stopped. Apply thin coat of high temp permanent thread lock to outside of the coil.. Insert coil til resistance, stop. Smooth sailing. Almost too smooth..
Old 04-22-2019, 03:32 PM
  #663
turboLScrx's Avatar
Good stuff! Glad it went that smooth for you ..... I’m going to save my congrats until you tighten that one. Lol.
Old 04-22-2019, 03:53 PM
  #664
DaX
DaX's Avatar
Sending good vibes your way!
Old 04-22-2019, 04:49 PM
  #665
Txdragon's Avatar
Yessir.. I'll celebrate when I get that one to 60lbs. Lol!
Old 04-23-2019, 09:29 AM
  #666
Txdragon's Avatar
So.. Good news, bad news.. Good news is that the repaired bolt hole held ARP recommend torque like a champ!! Bad news is that I popped ANOTHER thread on a different hole. Sigh.. I'm gonna hit all these now so I can put humpty dumpty back together again!
Old 04-23-2019, 11:18 AM
  #667
turboLScrx's Avatar
wow! I wonder what happened to make the head bolts want to strip out like this?
Old 04-23-2019, 11:22 AM
  #668
DaX
DaX's Avatar
I was worried about this happening. Yeah, might as well put inserts in all 10 holes now.
Old 04-23-2019, 11:31 AM
  #669
2x0
2x0's Avatar
Fatigue life of aluminum. No matter how much (or little) force is applied to it, it has a finite life span.
Also possible that at some point in it's past, the head studs were torqued improperly.
Old 04-23-2019, 11:35 AM
  #670
turboLScrx's Avatar
makes me cringe knowing that I torqued mine to 80
Old 04-23-2019, 02:35 PM
  #671
Txdragon's Avatar
Not sure why that happened. I had them torqued just fine beforehand and it was stock when I pulled it from the junkyard last year. Still had the stock headgasket too. Lol!
Anyhow, I see now what the "extension" is needed for; there are a couple bolt holes that will not fit the helicoil tool. I was able to drill with no issue but that's where I hit the wall. I suppose I can shave the tool shaft down to fit properly but after dealing with this **** all day today, I'm ready to just go find another block. Maybe I'll just go ahead and CSS that one.. ****...
Old 04-23-2019, 08:49 PM
  #672
JRCivic1's Avatar
I have found that blocks that have gotten HOT seem to get a bit brittle... especially with "D" and B20B/Z blocks. Pulling threads out of head bolt holes is common.
Old 04-24-2019, 10:37 AM
  #673
Moderator
TheShodan's Avatar
I hear ye, man. On my block (which was GE sleeved originally in 2003) when the threads stripped was due to the number of times the head has been torqued & removed, and torqued and removed over the years. I was the original owner of my block, so I knew that after so many races and head package change outs, it always starts out with either one or three at a time (in no particular order). I used a standard TimeSert set, and with my friend to help, we did all 10 of the holes.
On another block that my cousin bought that was already GE sleeved (bought used), there were already helicoils in it. Several of them were damaged already, as whoever had the block before had gone through a LOT of aftermarket head stud use/abuse. My machine shop wound up drilling them out, to use oversized TimeSerts, since it had already been helicoiled once. Turns out, the TimeSerts used as an Oversized application are exactly the same one used were the same ones that a GM NorthStar V8 uses!! The tooling was all the same except for drill bit. So no one had to purchase another kit, just 10 Oversized TimeSerts.
My point is that it's not a mistake to try the Helicoils due to cost. But you may CSS another block that is trustworthy, but now that you've seen this happen, have the CSS CNC WERX Team check out those stud holes first. I know for myself, I'll never use helicoils for headstud holes ever again. I could use helicoils on other areas, but not where so much tensile strength is used.
I'll post a few photos and video if you're interested
Old 04-24-2019, 12:48 PM
  #674
Txdragon's Avatar
The pics and vids are great documentation. Post them. I have a block already. The issue on that is this one had a bent rod and it smacked the bottom of the cylinder. I'll need to have it checked to see if it's good to use still. In my eyes, it's fine. I'm no professional though. If it's good, that saves me 120 off the bat. I'm considering getting it CSS and will have them inspect the holes for sure. I **MAY** have them just time-sert it for futureproofing. I'd hate to spend the money on the block to have it brought down by something as petty as bolt threads. Lol
Old 04-25-2019, 07:15 PM
  #675
Txdragon's Avatar
So... Situation update.. A local buddy of mine is chomping AT THE BIT to trade me for his B18C1 EK. it runs very well, I helped him with a few things in it. Body is straight, paint needs some help, interior is so-so.. Lots of clear coat peeling and a couple minor interior pieces missing. I don't Care about the little stuff like that. All I ask is straight body, as mine is, and VERY FEW, if any, mechanical hiccups.
Mine is not running but easy enough to get going with the stupid head bolt hole repairs. WELL OVER 5000 bucks invested..
I haven't said yes, but I haven't said no... I think all I'd keep is my turbo and wastegate. I haven't even discussed any details of a trade yet. I'm pissed and would hate to make a rash decision over a bullshit issue. Sigh..
Quick Reply: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
