Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon.. - Page 23 - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Old 02-26-2019, 06:58 PM
  #551
Txdragon's Avatar
Default Re: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
Originally Posted by turboLScrx View Post
I hate to hear that man! I grew up with bad knees and my body finally adjusted so I never had to have surgery...... hope the surgery goes well
Mine got jacked in the Army. I was on an Abrahms tank and NOTHING about that vehicle is forgiving. As a loader, your knees AND shoulders take a pounding. Lol! Not to mention the gym time.. That was partially my fault there.. I'd go twice a day, 1.5 hours each session, followed by a 4 mile run after each, 6 days a week.. Did this for 5 years.
Txdragon is online now
Old 02-26-2019, 07:18 PM
  #552
turboLScrx's Avatar
Ďyeah, you was hard on those dudes for sure!
turboLScrx is offline
Old 02-28-2019, 08:28 AM
  #553
Txdragon's Avatar
Ok so.. If I'm reading this right, I will have an efficient boost range of **approximately** 16-30 psi, and for 450hp I should be about 22psi? Or did I fall on my face interpreting this?
Old 02-28-2019, 10:35 AM
  #554
turboLScrx's Avatar
when you understand it....teach me lol. Itís something that is Greek to me
Old 02-28-2019, 11:53 AM
  #555
2x0
2x0's Avatar
Simple-fied by conversions
Of course, this is a vague generalization. But you get the drift.
2x0 is offline
Old 03-10-2019, 07:50 PM
  #556
Txdragon's Avatar
I'm fixing to start wading into deeper waters and touch up on the physics of boost. Something tells me I'm in for a ride here. I'll have some downtime to eat up very soon. First surgery in a week. Sigh.. I'll have to go easy on the pain killers if I want any info to really stick. Lol!
Old 03-11-2019, 03:02 AM
  #557
O.G. triple O.G.
NVturbo's Avatar
You should be thankful you didn't have to replace a "month old" oil pump like me yesterday. Take your time on your setup. Race War isn't until next month. LOL
NVturbo is offline
Old 03-11-2019, 03:23 AM
  #558
Txdragon's Avatar
That really sucks. Warranty return at least?
Old 03-11-2019, 03:29 AM
  #559
O.G. triple O.G.
NVturbo's Avatar
Nah...I ported and shimmed that pump so likely no. lol
New one, I left it alone. Was looking into Melling brand but bought a new Genuine Honda one on eBay. It was only $30 more, which wasn't too bad. Ordered Thursday and showed up late Saturday afternoon.
NVturbo is offline
Old 03-11-2019, 05:38 AM
  #560
Txdragon's Avatar
any idea on why it went kaput?
Old 03-11-2019, 08:13 AM
  #561
O.G. triple O.G.
NVturbo's Avatar
After I was done with the replacement, I removed the cover of the old pump and noticed scarring on the two gears. Like the gears were sliding around inside that area and eventually got jammed.
NVturbo is offline
Old 03-11-2019, 03:25 PM
  #562
DaX
DaX's Avatar
I went with a Melling pump on my Z6 - it doesn't sit 100% flush with the bottom of the block, and I think it's causing my oil pan gasket to leak. I may be replacing it with OEM soon.
The Melling pump I went with on my wife's Accord fit great and is working well.
DaX is offline
Old 03-11-2019, 04:46 PM
  #563
turboLScrx's Avatar
When it comes to a oil pump.... it’s OEM all the way, I used a Gates water pump since that’s who makes the ones for Honda from what I’ve learned but all o-rings or internal seals are OEM for sure. Then I used Clevite race bearings
Old 03-11-2019, 07:49 PM
  #564
Moderator
TheShodan's Avatar
When it comes to a oil pump.... itís OEM all the way, I used a Gates water pump since thatís who makes the ones for Honda from what Iíve learned but all o-rings or internal seals are OEM for sure. Then I used Clevite race bearings
Gates does NOT make OEM belts or oil pumps.. Those are made by Mitsusita or Toyoda Gosei. Bearings are by Taito/Daido. Brakes by Nissin.
TheShodan is offline
Old 03-12-2019, 02:22 AM
  #565
O.G. triple O.G.
NVturbo's Avatar
I went back with the factory Yamada oil pump. The previous pump was a Yamada as well, brand new when I first installed it a few months ago.
I don't like using non-factory pumps on Hondas because they usually don't fit. Misaligned mounting holes or casting is not even same shape.
NVturbo is offline
Old 03-12-2019, 04:42 AM
  #566
turboLScrx's Avatar
my mistake on that then, I was thinking Gates made the OEM water pump , Iím scared to run anything other than OEM bought from Honda on the oil pump. Only thing not OEM was my Gates water pump, JE Pro seal head gasket and the oil pan /valve cover gasket,
BIGthings
General Discussion and Debate
24
02-09-2008 04:11 PM
whytTypeR
01-04-2005 09:58 AM
dustin
03-21-2002 05:42 PM
Quick Reply: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
