Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
#526
Re: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
So I'm in another patch of downtime and I've really hit "the books" here lately on just various aspects of turbo research. I'm gonna throw it out there; it's not for the faint of heart. Soooo much info to take in. Most think that just choosing a kit is the best thing to do and even still, there's so much to consider. I'm kinda floored at the idea that people (including myself) have very little ACTUAL knowledge of what they're getting into, when they get into it.
#527
Moderator
#528
Today I learned the different "levels" of boost. I was way off before.
#529
O.G. triple O.G.
This day and age, people tend to think you can just "slap on" a turbo and expect miracles. I know factors such as engine work, health of the motor, quality of parts, etc. play a big role on how much power can be made. Yes, a turbo is a part of the equation too, along with the tuning process. That is why different setups make different power (output). Take for instance my current setup. From browsing several YouTube videos, people with similar setups make less or similar power, but at higher boost pressure. All different "ingredients" will yield different results.
#530
#531
O.G. triple O.G.
haha...I know what you mean, man.
** Wastegate, simple...TIAL
** FMIC...no Mishimoto, CXRacing (eBay junk), etc. PTE is okay but way overpriced. Narrowed down to the Treadstone TR8L and AutoWorks. Went with the Treadstone because of price and more commonly used by others.
** Turbo...no EBAY. Ball-bearing Garrett was out of my price range and I didn't want another PTE. Borg Warner was a good option too but couldn't find any that wasn't T4 flange.
Buying turbo parts was like shopping for a car. I literally looked at the same part, and the lowest price for it....for about 2-3 days. LOL
#532
Intercooler size and fin density, wastegate appropriately sized (this was actually **fairly** straightforward), turbo A/R and trim, flow rate, etc.. Ugh..
Coming from a decent build and a CX kit to a better build with a hand-selected kit. Wastegate will be tial MVS, Garrett journal bearing (ball bearing is also in the LOL price range for me) intercooler is a used Vibrant (great condition), manifold will be go Autoworks mini ram and 3" downpipe, full 3" custom exhaust (by me). I've read tons into a lot of this over the last several days and feel confident I'll end up where I want to be. Finishing it out with the tax return and **hopefully** will have it put together by mid-March. I plan on tuning at Keith Craft, they are about an hour from me. Although Mr. Craft has retired, his shop is still thriving. I don't know if they'll tune a Honda but eh, I can try!
#533
O.G. triple O.G.
just as long as the Vibrant FMIC doesn't have any leaks/cracks, it should work fine. I would at least clean the inside first before using it. As for tuning with a "non-Honda" tuner, just as long as they know what they're doing, you should be fine. If they aren't familiar or unable to set up the parameters for the tuning software/program you're using, I would go elsewhere.
#534
If they don't have a tuner that works with my software, it's all good. As long as I can rent some dyno time. I've been working with Neptune for 2 years now and feel completely comfortable with the program. All I need is the dyno to verify my timing adjustments. Plan B is to get a remote session with Phearable, should the dyno shop allow remote access to their equipment. Final plan is what I did the first time and E-tune with them again, then make my final adjustments on the dyno myself.
#535
O.G. triple O.G.
Yeah, a painted FMIC is fine, for the stealth look. However, some people will do that to hide damages.
Is there any other tuners in your area that can tune Neptune??
#536
My biggest concern here would be washing my rings but I'm almost certain my idle and partial are going to be a bit lean after my revamp. Idle before was at 14.7-15.3. I'm anticipating low to mid 15s with this setup. Possibly into low 16, so ring wash shouldn't be an issue. Too lean and I'll have trouble too but, I didn't really do any major porting so it shouldn't be an issue either. If the port cleanup and ferrea valves are enough to lean me out any more than that, I'll be very optimistic about good results here!
#537
O.G. triple O.G.
if your motor has good compression and acceptable clearance on the bearings and rings, it should make good power. That's where the issue lies with people's "built" motors. Due to lack of knowledge, incompetency or laziness, the motor is poorly put together. Then, they wonder why it only makes 220HP on 18psi of boost. LOL
#538
#539
O.G. triple O.G.
If all cylinders are at least 175+, you should be good. Mine was about 200 across the board...
#540
So it's been a crazy 3 days. The wife had to go out of town and I went along since the junkyard I normally visit is in that area. We checked into the hotel and within 5 minutes, the sky opened up and what followed was biblical.. It poured for hours. Ok, no problem, there's always tomorrow (yesterday). Weather forecast called for a high chance of rain, but not til after 1pm. Nope.. It didn't let up a bit from the time we woke up, til we went to bed. This morning was checkout and decided if it was nice, which it was SUPPOSED to be, we'd go by the boneyard on the way back home. Nope.. Not only was it raining, windy, and cold, but NOW there was fog that would make you swear you were trying to look through a large tank of milk.. Sigh.. We make the 2.5 hour drive home and within 15 minutes, all heavy rain we JUST drove 165 miles through stopped and the skies cleared up.. Another sigh.. Weather again supposed to be clear tomorrow but now, I'd trust the words of my ex-wife before I trust the weatherman..
I decided to make some good use of the nice weather though and got the head mounted and t-belt routed to set my valve lash again. TDC could NOT be set any more perfect now than would be from factory but, I've got no timing cover at all so, it's gonna get all torn down again to get THAT on. Still waiting as well on Uncle Sam to send my refund so I can get the last items. ANOTHER sigh..
#541
O.G. triple O.G.
I don't blame ya. It's been raining for 6 days straight here. I'm about to go collect some damn animals and build a ******' ARK. lol
Besides building a sub box for a friend, I had to swap out the LMAs in the Del Sol this wonderful rainy Saturday. Luckily, I still have my old motor on the engine stand. Took them out of my old motor and swapped them over. Sounds much quieter afterwards. The ones that were in my current motor were stiff as hell. For a minute there, I was afraid it was rod knock or something. I even re-adjusted the valve lash the other day, just as a precaution.
#543
Ice belongs in the freezer or a drink, not on the ground!! The pounding our east coast has been taking is dreadful. I have a few friends that had been snowed in for a couple days.. Ugh.. I can continue setting my valve lash tomorrow. It's all buggered up. The machinist was being very modest when he said I **might** have to adjust my rockers after resurfacing the head. Lol
#545
#546
And now for the bad news.. Well, not too bad but will be a big setback. I was just informed I'm gonna need another surgery on both knees. I kinda saw it coming and tried to avoid the doc but ugh.. Should be a quick recovery but still 8-12 weeks lost. Sigh..
#549
I hate to hear that man! I grew up with bad knees and my body finally adjusted so I never had to have surgery...... hope the surgery goes well
#550
It does, but the REAL fun part is that I get to go through as many scopes as necessary until 1 of 2 things happen; I hit the age I can get them replaced, or they finally debride enough bone and cartilage to warrant the replacement..
I'm going to start a pool, buy in of 5 bucks, to see which occurs first. Lol!
All the PT I've done over the last 16 years would be equal to going 40 hours a week for 4 and a half years straight.. I could have a degree in kinesiology with all the time I've put in. Lol!
