running 75 shot, blew motor, what happened?
ok so i was running a 75 shot on my d16y7 with upgraded plugs and wires, thats it. then the motor just shut off by itself in the middle of spraying. i restarted it and it wouldnt stay running unless i kept my foot on the gas and was running poorly when accelerating like on 3 cylinders. what do you think happened? the motor is now out of the car but im just curious to see what you guys think got damaged. anything internally?
Re: running 75 shot, blew motor, what happened? (hatchback_al)
Did you retard the timing? I melted the ring lands off two pistons on a 90 shot. It would barely stay running and it sputtered a lot. good luck man
Location: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy »</TD></TR><TR><TD CLASS="quote">Did you even check the plugs before pulling the motor?</TD></TR></TABLE>
what all did u check????
Re: Re: (twkdCD595)
Were you running a wet or dry kit? Probably a dry and it leaned out burnt a plug. I ran several bottles of 75 wet shots in my 91 lude with no problems. When things go wrong with nitrous, it's usually lean or to big a shot. But the plugs should reveal all.
Re: Re: (Timmay)
well, the truth is it happened to my friend and i want his motor for a rebuild. i dont know exactly what happened or what he checked, thats all the info i have i was just looking for examples of what might have happened. what are the chances that the block is still good. i mean that i can put in new pistons and rods including bearings and rings and have it be strong again. what usually is fucked over from something like this happeneing
