twin radiator setup - anybody tried ?
Inpoint of cooling problems while the hot temperatures we are thinking about a twin radiatorsetup.
We plan to take a halfsize radiator (maybe stock or double thick as stock) and add a second custom buildt radiator parallel between the stock radiator and the intercooler. There should be enough room to put it in.
The plan is to take a Y from the water feed line and lead it to the second radiator then lead the water back trough an other Y into the return.
Any ideas, suggestions or experiences?
Re: twin radiator setup - anybody tried ? (hondaapi)
same thing as double size radiator, only more worthless. If all that room will allow is a 1/2 sized radiator, i s'pose it'll work for keeping coolant temps lower... but.... oh man, need i go on?
if high temperatures are plagueing you, what is your setup? motor (stock/modified [w/ what specs], turbo setup; including your size of intercooler and turbo/boost pressure).
i have limited (but knowledgable) experience of turboed motors in hot weather climates; so whatever information i can provide you with, i will.
your far better off getting a nice racing style radiator. I run a koyo racing rad myself and have no issues with cooling. I actualyl have issues with it being too cool at times.
A good half-width should be fine. I ran a Fluidyne half-width on a 408 WHP Civic on road courses (probably the worst thing you con do for heat build-up) and my temps never wavered.
Two will fit though, I actually have two radiators in mine, but one is for my air-water intercooler. It's prett easy, just took me a few minutes to mount mine, made a small bracket for the top and used a thick piece of rubber hose on the bottom and rested it on my traction bar cross-piece. Here's a pic:
crxhybrid1320
07-01-2011 06:01 PM
The sweed
11-14-2008 11:51 AM
