turboXS MBC....are they that bad?
looking at the turboXS HP boost controller. since they claim..."The ball and spring mechanism keeps pressure out of the wastegate until the preset boost level is reached, significantly reducing wastegate creep and providing quicker turbo spool up."
did a search and the opinions on them are 50/50. some say boost creep, some say there is no boost creep.
i basically want a cheap boost controller. are the worth the money?
Re: turboXS MBC....are they that bad? (onePOINTsix)
i used one on the race car turbo xs high performance no issues no creep held boost fine on large turbo too
Re: turboXS MBC....are they that bad? (1.8)
I run a JoeP MBC, same design.
Works perfect, no creep or spikes, just ******* plants at 16psi and tells everything else to **** off lol
Got it for $25
Got it for $25
use one on a b16 with a gt28, internally gated. creeps from 5 to 8psi.
when the same manifold, turbo, and mbc were used on a b18, crept from 8 to 11psi.
fairly sure the little rubber washer inside was useless... replacing that would probably help. it leaks.
Who is Mr Robot?
Re: turboXS MBC....are they that bad? (warrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick »</TD></TR><TR><TD CLASS="quote">use one on a b16 with a gt28, internally gated. creeps from 5 to 8psi.
fairly sure the little rubber washer inside was useless... replacing that would probably help. it leaks.</TD></TR></TABLE>
internal gate, thats your problem
we run there dual stage on all our cars, I would say most of the 9 second sport fwd cars run em... think they work pretty good, never creeps, responce is great between stages....
they don't seem to like vacume much. i had mine installed on the throttle body, and it leaked, and the car idled really crapy. moved it over to the port on the front of the intake manifold (d16y8) and it idled alot smoother and no leaking. no idea why the location made a differance.
make sure you install them the right way or they are usless.
good overall review from me. used one on 4 cars, and about 6 diffecnt setups.
Re: turboXS MBC....are they that bad? (Snail Tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail Tuning »</TD></TR><TR><TD CLASS="quote">they don't seem to like vacume much. i had mine installed on the throttle body, and it leaked, and the car idled really crapy. moved it over to the port on the front of the intake manifold (d16y8) and it idled alot smoother and no leaking. no idea why the location made a differance.
good overall review from me. used one on 4 cars, and about 6 diffecnt setups. </TD></TR></TABLE>
i always thought that they're suppose to be hooked up on the intake manifold side. but if i had a vacuum manifold, i wouldn't have this problem, right?
yeah i run my HomeMade boost controller off of a vac manifold, with vac comming from the brake booster. This is the third boost controler ive used in a week and its the only one that holds boost like its supposed to.
check this link... it doesn't hurt to try it out... it cost me a total of almost $12. My only difference is that i used a wing nut for a jamb nut.
http://www.geocities.com/chmwatson/FAQs/mbc.html
Run a hallman MBC.... i've seen car made over 400whp that uses it... it was holding 27+psi... it doesnt creep or spikes...
http://www.gruppe-s.com/Subaru/subeng/hallman.htm
Re: (YASH)
like any bleed you have to turn it up to it's threshold, once there just turn it a slight bit like 1/8th of a turn and you should get a 1 psi increment...
bodea_florian
08-25-2004 06:54 PM
brasilstreet
06-16-2004 02:21 PM
