TurboXS manual boost controller! I need help, going to the track in 45 min!!
i need to get this thing on before i head out to the track. i know where to hook it up, but which port goes to which side of the mbc? does the brass side go to the wastegate and hte blue side go to the turbo side??
also how do you adjust it? do you screw the screw in the middle?? is that a allen hex key? thanks guys.. i wanna up the boost before my runs tonight |
Re: TurboXS manual boost controller! I need help, going to the track in 45 min!! (TurbothisLS)
The bottom of the mbc goes to the side of the wastegate. On it there should be a directional arrow that shows you which way to turn to adjust the boost. Yeah its an allen wrench to adjust it. It should of came with one. Keep the mbc all the way down to see if it holds the boost then adjust from there. Its about 1 turn per psi.
Re: TurboXS manual boost controller! I need help, going to the track in 45 min!! (Etylorcen)
17.8 @ 50 mph, 4 psi of boost http://images.zeroforum.com/smile/emthup.gif glad u got the turbo in buddy ! seriously though get any good times tonight ?
what if one were to have switched those two ports...
