TurboLScrx - Making my return to the fold
#701
Re: TurboLScrx - Making my return to the fold
‘My last run was a perfect run but yet only went 129mph and it felt odd like I was pulling a boat, either the car got warm and something in the program pulled timing or the clutch was letting go. I’ll figure it soon..... also need to figure my 2 step out and get my launch down, right now it’s building to much boost pressure on the 2 step
#702
With the car getting warm, it looks like my timing got pulled my as much as 5 deg, that would explain the loss of 10mph.
#703
I didn’t get to data log that run, my temp gauge was about midway or a little over on the dash. I’m just not exactly sure what the actual temperature maxed out at. I’ve got things setup to pull timing at different temp thresholds and I’m not sure if it hit the 2nd threshold or not.... I know it did the first which was 3 deg pulled. I hot lapped the car on a 90 deg day which I would never normally do, but if you watched the video, you know the storms was chasing me. Lol
#705
#706
For IAT it is harder to control, but I only have mine start retarding after 130°, goes to -1.5° at 150° then tapers to -4° at 300°. Although the highest IAT I've ever seen was probably in the 140's. Still feels like a turd though when it gets that hot just because of the loss of air mass.
#707
On e85 you should not need to pull that much timing due to increase in ECT or IAT, depending on how aggressive your timing is to begin with. If ECT is your problem you should address it so that the car never gets above the temp you need it to, with a better cooling fan or increasing air flow. That way you should not have to worry about pulling timing if it gets "hot".
#708
I don’t think I’ll run into this very often, this was the first time I ever got it to overheat a little . It was 90 degs and muggy as crap and I hot lapped the car which I never normally do, I was just trying to beat the storm. I can drive the car all day and it won’t over heat, put forcing 600hp through it changes things. Lol
#709
See, simple stuff!
#711
Just caught up, good to see that the clutch wasn't that much of a setback and props for getting it back together so quick. Sweet trailer. Looking forward to seeing what it can do next time you're able to make it to the track
#712
Appreciate that, I’m afraid I may have hit a wall until I get my boost by gear working. When I turn up the boost I blow the tires off, but the lower boost settings will probably max out in the 10.30-10.40 range. I wasn’t ready to spend money on a new computer yet, but I’ll see how things go
#713
#714
The walls we hit are unfortunate. Especially the small ones like this. Not really small but.. It's one of those problems that just seem stupid to have but, still a problem. Lol. In a situation like this, I try to see how I can make it work then give a valiant attempt. Should I fail, then I reach for remedy. You got this, brotha!!
#715
#718
#719
Absolutely! Once you hit 10’s it seems every little demon shows his ugly little face.my biggest problem is catching up weak parts on my setup that wasn’t ready for how fast the car has become. I really didn’t expect to get this fast this fast. Lol. I need about 2 hours on a dyno and my boost by gear working and I’ll run a 9.80
#720
It seems the demons show their ugly head when bolting up that turbo kit alone.
#721
I think once you get low 10's high 9's you are on the limit of having to spend big bucks and have to make the decision LOL.
#722
Roll cage starts within two weeks! I will be doing the assembly and welding, but that should not be a issue with my ability to weld. I’m doing a 10 point through dash setup, this is something I really should have already done but I didn’t expect to making my power level so fast. During the dead heat of summer while racing is at a crawl is the perfect time to get this cage done.
#723
So what you're saying is there's gonna be a cage match soon?!
#725
more than likely you will be correct. Lol
I ordered mine from a company that specializes in roll cages.... the price was very fair
