TurboLScrx - Making my return to the fold
Old 06-10-2019, 10:34 AM
  #676
turboLScrx's Avatar
Default Re: TurboLScrx - Making my return to the fold
Originally Posted by b18apwr View Post
Acura/Honda part numbers:
Driver side (intermediate shaft): 91205-PL3-A01
Passenger side: 91205-PC9-711
Look at you lol Thank you.
turboLScrx is offline
Old 06-10-2019, 11:14 AM
  #677
Txdragon's Avatar
That was good looking out! Gotta remember though, it's all about the parts monkey pulling the right ****. Lol!
Txdragon is online now
Old 06-10-2019, 04:01 PM
  #678
turboLScrx's Avatar
ENGINE IS GOOOOOD!!!!!!!!! I need to still snap the axles in and a few bolts...... but it sounds very healthy, itís a huge relief hearing it run CORRECTLY!!
Old 06-10-2019, 04:09 PM
  #679
DaX
DaX's Avatar
DaX is offline
Old 06-10-2019, 04:43 PM
  #680
Txdragon's Avatar
Now stop breaking stuff!!
Old 06-11-2019, 04:26 PM
  #681
turboLScrx's Avatar
Welp...... I got everything back together tonight, and it turned into a oh **** moment. I fired the car up and it sounded just as it should, so I just needed to verify that the transmission was ok by going through the gears while the car was running. ( car is still on jack stands ) Soon as I went to release the clutch in 1st gear I could see the wheel jerk and the car stalled out, I tried multiple times with the same result. I put the car in neutral and released the clutch and the same result, now with the clutch pushed in or the car off it’s easy to shift through the gears but soon as the clutch was let out it’s over. I about gave up knowing I was going to need to take the transmission back out and apart to see what I could have missed, put I finally got pissed off and started the car .... reved up the engine and released the clutch in reverse....... I had a little thud and the wheels took off spinning!! Come to find out the Carbon synchros apparently got to dry with everything being apart and they was sticking and holding the transmission from turning somehow. I let the transmission spin for a minute and the gears started shifting smoother and smoother. I knew the carbon synchros needed oiled during installation which I did a few days ago, but they dried out enough I guess to cause this. This is the first time I’ve ever seen this happen and hoping it’s the last lol. I had twoorder two bolts from Honda which will be here in the morning and I’ll should be back on the street tomorrow........
Old 06-11-2019, 04:41 PM
  #682
AZ_CIVIC's Avatar
Did you get a new clutch setup?
AZ_CIVIC is offline
Old 06-11-2019, 05:11 PM
  #683
Txdragon's Avatar
I would hope so because that last pressure plate looked unserviceable!!
Old 06-11-2019, 05:12 PM
  #684
turboLScrx's Avatar
I picked up a replacement stage 4 CC single disc and a new flywheel for now, before I spent the money on a twin disc I needed to make sure the engine was not hurt....I also found a hydro transmission and converted the car back to hydro while things was apart. I didn’t want to buy a twin disc that only worked with the old cable transmissions. Now that I know the engine is ok, I’ll start saving for that twin disc
Old 06-11-2019, 05:15 PM
  #685
turboLScrx's Avatar
I bet JB Weld would hold it
Old 06-11-2019, 05:18 PM
  #686
Txdragon's Avatar
Haaahahahahahaaaa!! JB weld and send it!!!
Old 06-11-2019, 05:45 PM
  #687
AZ_CIVIC's Avatar
I picked up a replacement stage 4 CC single disc and a new flywheel for now, before I spent the money on a twin disc I needed to make sure the engine was not hurt....I also found a hydro transmission and converted the car back to hydro while things was apart. I didnít want to buy a twin disc that only worked with the old cable transmissions. Now that I know the engine is ok, Iíll start saving for that twin disc
Nice, good to see it back together!
AZ_CIVIC is offline
Old 06-12-2019, 02:28 PM
  #688
turboLScrx's Avatar
So far so good! And Iíve already strapped down the battery
Old 06-12-2019, 04:10 PM
  #689
Txdragon's Avatar
When's the next passes at the track?
Old 06-12-2019, 05:44 PM
  #690
turboLScrx's Avatar
ĎItís possible I might hit a 1/8 mile track Friday night down in Nashville , There are big events this weekend at my local track
  • Ask a Question
Question Title:
Description:
