TurboLScrx - Making my return to the fold
Old 02-22-2019, 03:29 PM
  #351
turboLScrx's Avatar
Default Re: TurboLScrx - Making my return to the fold
This is all I can say right now!
Old 02-22-2019, 04:10 PM
  #352
turboLScrx's Avatar
Originally Posted by solo227
Had me nervous just reading the story lol You really moving man. Keep up the good work..
I appreciate that, after I fired it up today my oil pressure was a solid 85psi under throttle
Old 02-22-2019, 05:38 PM
  #353
AZ_CIVIC's Avatar
Sry nice man, sounds 👍
Old 02-22-2019, 05:47 PM
  #354
turboLScrx's Avatar
thanks AZ. Sounds like it has good compression so far, I’ll do a 3rd heat cycle tomorrow and then do a compression test. I’m thrilled right now to hear it fire up!
Old 02-22-2019, 06:03 PM
  #355
Txdragon's Avatar
It lives!!! Congrats!
Old 02-23-2019, 08:56 AM
  #356
turboLScrx's Avatar
thanks! I did another heat cycle this morning and it’s hard to believe how responsive the throttle is..... this motor feels very alive. Lol
Old 02-24-2019, 04:08 AM
  #357
DaX
DaX's Avatar
Another congrats!
Old 02-24-2019, 05:16 AM
  #358
turboLScrx's Avatar
Originally Posted by DaX
Another congrats!
thanks. After I install the pontoons on my civic I might take it for a test drive to put some miles and load on the motor
Old 02-24-2019, 02:55 PM
  #359
turboLScrx's Avatar
I Was able to finish all the lines and hoses and go through a few heat cycles over the past few days and today I took it out for a 30-40 mile drive. I’m proud to say that it’s all still together lol.... for now anyway. I was a little nervous about oil pressure considering I ported out / modified my oil pump and we used bigger tolerances on the main bearings than most people are used to using, but I’m very pleased with the car holding around 35psi as it goes above 1000rpms and 68psi at 2000rpms and close to 80 psi by 4000rpms. (Full temp). I’ll do my first oil change tomorrow and hope to start some tuning within the next two weeks.
Old 02-24-2019, 05:39 PM
  #360
Txdragon's Avatar
What oil weight are you using? 15w40 rotella?
Old 02-24-2019, 05:45 PM
  #361
turboLScrx's Avatar
break in is normal 10w-30 Valvoline, then I’m switching over to Valvoline VR1
Old 02-24-2019, 05:51 PM
  #362
Txdragon's Avatar
I see. I was way off. Lol! The VR1 looks good and has my attention. I'm concerned a tad about my main clearances as well and wondering how thick is too thick? They have 20w50 turbo approved oil. Would that be a bit much?
Old 02-24-2019, 06:00 PM
  #363
turboLScrx's Avatar
I was told my a very respected Honda builder to use those oils for the break in process and final...
what is you mains clearance? Mine was set .0025
Old 02-24-2019, 06:30 PM
  #364
AZ_CIVIC's Avatar
I’ve been using Brad Penn 20-50.
Old 02-24-2019, 06:39 PM
  #365
O.G. triple O.G.
NVturbo's Avatar
That's what I'm using. Cheap and readily available....
Old 02-24-2019, 06:43 PM
  #366
Txdragon's Avatar
My main clearances are a tad higher, .0028
Old 02-24-2019, 07:02 PM
  #367
turboLScrx's Avatar
‘I’m sure a little thicker oil would be fine, but the oil pressure reading will tell all. I made sure to shim my pump to increase the pressure to make up for the extra bearing clearance. I know the weight that people use will very depending of the environment you live in, 10w-30 is a very universal oil that’s very common in central US where we have all 4 seasons
Old 02-24-2019, 07:04 PM
  #368
turboLScrx's Avatar
‘that’s a pretty heavy oil, but I guess you live in a very hot area. That’s close to what I use in my two 7.4 liter marine motors
Old 02-24-2019, 07:50 PM
  #369
Txdragon's Avatar
Yeah I shimmed and ported my oil pump
I'm going to want to add an oil pressure gauge now to keep an eye on things for a bit anyways.
Our weather is crappy in the summer and spring, not too bad in the fall and winter can get pretty nippy.
Old 02-25-2019, 05:46 AM
  #370
AZ_CIVIC's Avatar
Yes but I use that oil year around, the oil also has a zinc additive which is good on cam wear especially when using a bigger cam. Also just think about how hot the oil gets when racing, a light weight oil with warm weather and multiple drag passes will turn into water.
Old 02-25-2019, 06:53 AM
  #371
maxwellmercer's Avatar
Yes, that first start is always so exciting! Hopefully everything stays smooth with your oiling issue!
Old 02-25-2019, 08:03 AM
  #372
turboLScrx's Avatar
‘so far so good! Like AZ said, I’ll be switching over to a high zync oil pretty soon, but for now I’m just going to be working out any bugs on a basic tune then start swapping over to the large injectors and 4 bar map sensor before hitting the dyno
Old 02-25-2019, 05:06 PM
  #373
turboLScrx's Avatar
Was able to get the car about for a while this evening and it was the first time I’ve been able to engage vtec, this is where my problem came in.....as soon as vtec tries to engage the car starts to stutter almost like there is no fuel and the car nose dives. My A/F is fine going into vtec and It don’t matter which gear I’m in, it had the same results. I have the vtec engagement at 4700 and with old cams that worked perfectly but with the Skunk2 pro1 cams I’m sure that won’t work, but I’m not sure that’s what’s caused the issue or not. Unless someone else has had this issue I guess I’ll raise the vtec up or disconnect it and see if the problem is with rpm levels or the actual vtec
Old 02-25-2019, 05:14 PM
  #374
Txdragon's Avatar
Is it actually stuttering like a fuel or boost cut or does it just feel like, flat? Like all power just goes to pot?
Old 02-25-2019, 05:34 PM
  #375
turboLScrx's Avatar
‘feels like boost cut, I’ve not been above 4-5 psi yet, it pretty much shuts things down. I’ve not changed anything in my program from when I pulled the motor, I know I’ll need to to retune the car, but I wouldn’t think things would be that far off to cause something like this
Quick Reply: TurboLScrx - Making my return to the fold
