turboed b20b long block
Old 04-19-2005, 12:01 AM
idriveadelsol7's Avatar
Default turboed b20b long block
anybody here seen or read of a boosted b20b (going in a del solby the way)? how's it compared to the b18b? i plan to sleeve it. rods | pistions... thank you. appreciate it.
Old 04-19-2005, 12:05 AM
s2kdre's Avatar
Default Re: turboed b20b long block (deLasoL7)
a stock b20? its similiar to a b18b a little less hp with 9:2:1 compression, and the sleeves are thinner so you cant boost as much as a b18.
Old 04-19-2005, 12:06 AM
Default Re: turboed b20b long block (jdmhonda)
ya.. i was editing the post... i was going to get some darton sleeves. should i slap on a b16 head? or leave it alone.
Old 04-19-2005, 12:11 AM
I can has title
Cor ey's Avatar
If you want more power go ahead and slap the b16 head on...search around, I'm sure there is plenty of info on this topic.
Old 04-19-2005, 12:14 AM
Default Re: turboed b20b long block (96B_97E)
yups, i've been reading up. just wanted to see how it compares to the b18b
Old 04-19-2005, 01:00 AM
BLANKS143's Avatar
theres no replacement for displacement :D
Old 04-19-2005, 01:22 AM
SAMIboarder's Avatar
If you're gonna sleeve it, hell yeah. If not, keep the boost down. view my sig.
I went from a B16A (10psi, .48/.63 T3/T04E) w/ 9.5 CR to the B20 block w/ same set up.....OMG....The torque and instant spool was amazing. I expected power to drop top end w/ my smaller exhaust housing, but it didn't feel like it. sadly, it didn't see the dyno so I'm not sure. I miss that monster.
Old 04-19-2005, 03:09 AM
Redwidow's Avatar
I have a B18B changed to a B20 GE sleeved in my civic with a GSR P/P head and all the works.. If your going with a B18B/B20B bottom end you could go with either block and just sleeve it as your saying. Keep in mind there are things you will want to upgrade like oil pump, get your head milled to match the block or get dowells which is much easier. If you can get a GSR block<it can have stock sleeve damage ie cracked sleeve, which will be cheaper to buy> slap a B20B/B18B crank with little machining and then you have a better set-up.
Old 04-19-2005, 08:06 AM
Default Re: turboed b20b long block (Redwidow)
lets say i decide to just run it without a vtec head? is 300 whp possible?
Old 04-19-2005, 09:55 AM
Calvinator's Avatar
Default Re: (BoostedB20Z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedB20Z &raquo;</TD></TR><TR><TD CLASS="quote">theres no replacement for displacement :D</TD></TR></TABLE>
theres no replacement for displacement, except boost..haha
Old 04-19-2005, 10:55 AM
BLANKS143's Avatar
Default Re: (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">
theres no replacement for displacement, except boost..haha</TD></TR></TABLE>
but displacement + boost = the WIN! lol
Old 04-19-2005, 03:06 PM
is 300 hp on a without a vtec head possible?
xtahjhd
08-31-2015 06:52 AM
takenbycause21
09-22-2004 03:26 PM
hmongdude
05-27-2003 01:18 PM
lbz34
05-26-2002 11:37 AM
KRiS1
03-29-2002 06:08 AM
Quick Reply: turboed b20b long block
